Change Poster 1.0-fix5 with Stop Posts Count From Increasing 1.0
Beitragvon AmigaLink » 12. Jan 2007 17:05
Damit der "Change Poster MOD" die Beitragszähler der User nicht verändert, wenn in einem Forum die Beitragscounter -mittels des "Stop Posts Count From Increasing MODs"- deaktiviert wurden, ist diese kleine Änderung nötig:
changeposter.php
         $topic_id = intval($row['topic_id']);
// Stop Posts Count From Increasing addon by AmigaLink
// -- add forum_id,
      $sql = "SELECT topic_first_post_id FROM " . TOPICS_TABLE . "
#-----[ INLINE FIND ]---------------------------------------------------------
SELECT
#-----[ INLINE AFTER, ADD ]---------------------------------------------------
forum_id,
         $topic_first_post_id = intval($row['topic_first_post_id']);
         $forum_id = intval($row['forum_id']);
      $sql = "UPDATE " . USERS_TABLE . " SET user_posts= " . $newuser_posts ." WHERE user_id =" . $newposter_id;
   if( strstr($board_config['no_post_count_forum_id'], ',') )
      $fids = explode(',', $board_config['no_post_count_forum_id']);
      while( list($foo, $id) = each($fids) )
         $fid[] = intval( trim($id) );
      $fid[] = intval( trim($board_config['no_post_count_forum_id']) );
   reset($fid);
   if ( !in_array($forum_id, $fid) )
      // * change topicstarter if necessary
