von AmigaLink » 12. Okt 2004 19:04
			Macht den "Select default language Mod" phpBB 2.0.10 kompatible!
- Code: Alles auswählen
## MOD Title:          Select default language - fix
## MOD Author:         Niels < ncr@db9.dk > (Niels Chr. Rød) http://mods.db9.dk
##             fix put to paper by Billy Regal <email@billyregal.de>
## MOD Version:        1.3.4
## MOD Compatibility:  2.0.4->2.0.6 (prior release not tested)
## FIX Description:    This fix sould be applied in case
##             you are getting MySQL Error in the Header,
##             mostly occuring in the Internet Explorer.
##             Mozilla seems to do just fine.
## Installation Level: Easy
## Installation Time:  1 Minute
## Files To Edit:      1
##      common.php
## Included Files:     0
## Author Notes:
## 1. Full MOD description
## This fix is not my work, I picked it up in a forum,
## can't remember exactly where. Billy
#-----[ OPEN ]------------------------------------------------
common.php
#-----[ FIND ]------------------------------------------------
$dir = opendir($phpbb_root_path.'language');
      $lang_d = array();
      while (false !== ($file = readdir($dir)))
         if ( ereg("^lang_", $file) && !is_file($dirname . "/" . $file) && !is_link($dirname . "/" . $file) )
            $filename = trim(str_replace("lang_", "", $file));
            $displayname = preg_replace("/^(.*?)_(.*)$/", "\\1 [ \\2 ]", $filename);
            $displayname = preg_replace("/\[(.*?)_(.*)\]/", "[ \\1 - \\2 ]", $displayname);
            $lang_d[$displayname] = '1';
      closedir($dir);
      @asort($lang_d);
      @reset($lang_d);
      while ( list($displayname, $filename) = @each($lang_d) )
         if (strpos($displayname,$_SERVER['HTTP_ACCEPT_LANGUAGE'])===0)
            $language = $displayname;
            $board_config['default_lang'] = $language;
            break;
# just put comment around it
      $lang_d = array();
      closedir($dir);
      @asort($lang_d);
      @reset($lang_d);
            break;
#-----[ SAVE/CLOSE ALL FILES ]--------------------------------
