von AmigaLink » 14. Mär 2005 21:31
			Dieses addon fügt der Amazon Box v1.00 von
AWSW eine, im ACP, frei konfigurierbare Anzahl von Reihen hinzu.
- Code: Alles auswählen
#----------[ RUN SQL ]----------------------------------
#  Run the following SQL statement to update your phpBB database.
#  You can use phpMyAdmin or a similar tool to run this update.
#  IMPORTANT: If you have changed the table prefix from the default of phpBB2,
#  please be sure to replace phpBB2 with your prefix BEFORE running this update.
INSERT INTO `phpbb_config` VALUES ('amazonbox_rows', '3');
language/lang_english/lang_admin.php
$lang['AmazonBoxLimit'] = 'Limit';
$lang['AmazonBoxRows'] = 'Rows';
$lang['AmazonBoxRows_exp'] = 'Enter the number of displayed rows here.';
$lang['AmazonBoxLimit_exp'] = 'Enter the number of displayed values here.';
$lang['AmazonBoxLimit_exp'] = 'Enter here the number of displayed values per row.';
language/lang_german/lang_admin.php
$lang['AmazonBoxRows'] = 'Reihen';
$lang['AmazonBoxRows_exp'] = 'Trage hier die Anzahl der auszugebenden reihen ein.';
$lang['AmazonBoxLimit_exp'] = 'Trage hier die Anzahl der auszugebenden Werte ein.';
$lang['AmazonBoxLimit_exp'] = 'Trage hier die Anzahl der auszugebenden Artikel, pro reihe, ein.';
admin/admin_board.php
'AmazonBox' => $lang['AmazonBox'],
'AmazonBoxRows' => $lang['AmazonBoxRows'],
'AmazonBoxRows_exp' => $lang['AmazonBoxRows_exp'],
"amazonbox_limit" => $new['amazonbox_limit'],
"amazonbox_rows" => $new['amazonbox_rows'],
templates/subSilver/admin/board_config_body.tpl
      <td class="row1">{AmazonBox} - {AmazonBoxLimit}:<br><span class="gensmall">{AmazonBoxLimit_exp}</span></td>
      <td class="row2"><input class="post" type="text" name="amazonbox_limit" size="3" maxlength="3" value="{amazonbox_limit}" /></td>
      <td class="row1">{AmazonBox} - {AmazonBoxRows}:<br><span class="gensmall">{AmazonBoxRows_exp}</span></td>
      <td class="row2"><input class="post" type="text" name="amazonbox_rows" size="3" maxlength="3" value="{amazonbox_rows}" /></td>
includes/page_tail.php
// AMAZON BOX START
$amazonbox_limit = $board_config['amazonbox_limit'];
    $sql = "SELECT word, replacement FROM " . AMAZONBOX_TABLE . " ORDER BY RAND() LIMIT " . $amazonbox_limit;
            message_die(GENERAL_ERROR, 'Could not obtain amazonbox information', '', __LINE__, __FILE__, $sql);
    while ($row = $db->sql_fetchrow($result))
    $word = $row['word'];
    $replacement = $row['replacement'];
            $template->assign_block_vars("amazonbox", array(
            'word' => $word,
            'AmazonImg' => $replacement,
            "AmazonLink" => "http://www.amazon.de/exec/obidos/ASIN/" . $replacement . "/" . $board_config['amazonbox_partnerid']
// AMAZON BOX END
// AMAZON BOX START
$amazonbox_rows = $board_config['amazonbox_rows'];
$amazontipps = $amazonbox_rows * $amazonbox_limit;
    $sql = "SELECT word, replacement FROM " . AMAZONBOX_TABLE . " ORDER BY RAND() LIMIT " . $amazontipps;
   $amazondata = array();
      $amazondata[] = $row;
   $tippnr = 0;
for ($i = 0; $i < ($amazonbox_rows); $i++)
   $template->assign_block_vars('boxrow', array());
   for ($j = $i; $j < ($i + $amazonbox_limit); $j++)
      if( $tippnr >= count($amazondata) )
         break;
      $word = $amazondata[$tippnr]['word'];
      $replacement = $amazondata[$tippnr]['replacement'];
      $template->assign_block_vars("boxrow.amazonbox", array(
            'word' => $word,
            "AmazonLink" => "http://www.amazon.de/exec/obidos/ASIN/" . $replacement . "/" . $board_config['amazonbox_partnerid'],
      $tippnr++;
$template->assign_vars(array(
      'amazonbox_limit' => $amazonbox_limit
// AMAZON BOX END
templates/subSilver/overall_footer.tpl
<!-- ##### AMAZON BOX START ##### -->
<br><center><table border="0" cellpadding="1" cellspacing="1" style="border-collapse: collapse" class="forumline">
        <td class="catHead" colspan="{amazonbox_limit}" height="25"><span class="cattitle"><center><b>{AmazonBox}:</b></center></span></td>
        <td colspan="{amazonbox_limit}" height="1" class="row3"><img src="images/spacer.gif" width="1" height="1" alt="."></td>
  <!-- BEGIN amazonbox -->
      <td class="row1" align="center"><a href="{amazonbox.AmazonLink}" target="_blank" class="gensmall"><img src="images/amazonimages/{amazonbox.AmazonImg}.jpg" title="{amazonbox.word}" border="0"><br>{amazonbox.word}</a></td>
  <!-- END amazonbox -->
</table></center><br>
<!-- ##### AMAZON BOX END ##### -->
<br><center><table border="0" cellpadding="1" cellspacing="1" style="border-collapse: collapse" class="forumline" width="100%">
      <td class="spaceRow" colspan="{amazonbox_limit}" height="1"><img src="images/spacer.gif" width="1" height="1" alt="" title=""></td>
  <!-- BEGIN boxrow -->
      <td class="row1" align="center"><a href="{boxrow.amazonbox.AmazonLink}" target="_blank" class="gensmall"><img src="images/amazonimages/{boxrow.amazonbox.AmazonImg}.jpg" title="{boxrow.amazonbox.word}" border="0"><br>{boxrow.amazonbox.word}</a></td>
  <!-- END boxrow -->
