Version cache mod (phpBB 2.0.12 or newer only)
Beitragvon AmigaLink » 20. Jul 2005 22:48
CyberAlien hat geschrieben:phpBB 2.0.12 checks for latest phpBB version in admin control panel. It checks for version every time you open admin control panel index and it slows down acp index for few seconds (it depends on your host's connection to phpbb.com and phpbb.com speed).
This mod caches result returned by phpbb.com, so instead of checking for update every time you open acp it checks for update only once in 24 hours. So acp index opens faster and phpbb.com gets less queries.
Note: chmod directory "cache" to 777 to make cache writable.
## MOD Title: Version Cache mod
## MOD Version: 0.01
## MOD Author: CyberAlien <no@public_email> (Vjacheslav Trushkin) http://www.phpbbstyles.com
## MOD Description:
##      This mod caches phpBB version update information so phpBB checks
##      for update only once a day instead of checking it every time you
##      open admin control panel index.
## Installation Level:   Easy
## Installation Time:   1-2 Minutes
## Files To Edit (1): admin/index.php
#-----[ OPEN ]---------------------------------------------
admin/index.php
#-----[ FIND ]---------------------------------------------
# around line 570
   if ($fsock = @fsockopen('www.phpbb.com', 80, $errno, $errstr))
#-----[ BEFORE, ADD ]---------------------------------------
   // Version cache mod start
   // Change following two variables if you need to:
   $cache_update = 86400; // 24 hours cache timeout. change it to whatever you want
   $cache_file = '../cache/phpbb_update_' . $board_config['default_lang'] . '.php'; // file where to store cache
   $do_update = true;
   if(@file_exists($cache_file))
      $last_update = 0;
      $version_info = '';
      @include($cache_file);
      if($last_update && !empty($version_info) && $last_update > (time() - $cache_update))
         $do_update = false;
   if($do_update)
      // Version cache mod end
# around line 641
   $version_info .= '<p>' . $lang['Mailing_list_subscribe_reminder'] . '</p>';
#-----[ AFTER, ADD ]---------------------------------------
      if(@$f = fopen($cache_file, 'w'))
         fwrite($f, '<' . '?php $last_update = ' . time() . '; $version_info = "' . addslashes($version_info) . '"; ?' . '>');
         fclose($f);
         @chmod($cache_file, 0777);
Mod is available in .mod format here: http://files.phpbbstyles.com/ca/mod_versioncache.txt
Zugefügt nach 142 Tag(en) 10 Stunde(n) 20 Minute(n):
Von diesem Snippet ist mittlerweile eine neuere Version verfügbar. :arrow: http://www.amigalink.de/dl_detai ... d=84&cat=8
