von AmigaLink » 2. Feb 2005 16:05
			Beispielcode für den index:
- Code: Alles auswählen
$lang['Quiz_answer_hidden'] = "Die Antworten werden erst angezeigt wenn das Quiz beendet wurde.";
$lang['Next_quiz'] = "Die nächste Quizfrage wird am %s gestellt.";
$lang['Quiz_answer_hidden'] = "The answer is only shown if the quiz is finished.";
$lang['Next_quiz'] = "Next quiz question will post at %s.";
index.php
// Generate the page
// Next Quiz time
$sql = "SELECT * FROM " . QUIZ_CONFIG_TABLE;
if ( $result = $db->sql_query($sql) )
      while ( $row = $db->sql_fetchrow($result) )
         $quiz_config[$row['config_name']] = $row['config_value'];
      message_die(GENERAL_ERROR, 'Could not query quiz_config information', '', __LINE__, __FILE__, $sql);
$next_quiz = create_date($board_config['default_dateformat'], $quiz_config['next_quiz'], $board_config['board_timezone']);
$template->assign_vars(array(
   'NEXT_QUIZ' => sprintf($lang['Next_quiz'], $next_quiz)
index_body.tpl
   <td class="row1" align="left"><span class="gensmall">{TOTAL_USERS_ONLINE}   [ {L_WHOSONLINE_ADMIN} ]   [ {L_WHOSONLINE_MOD} ]<br />{RECORD_USERS}<br />{LOGGED_IN_USER_LIST}</span></td>
   <td class="row1" align="left"><span class="gensmall">{NEXT_QUIZ}</span></td>
