von AmigaLink » 27. Feb 2007 12:38
			- Code: Alles auswählen
viewtopic.php
   if (!$parsed || !$board_config['enable_post_cache'])
      $message = $postrow[$i]['post_text'];
      if ( preg_match("/\[hide\:[0-9a-z\:]+\]/si", $message) || preg_match("/\[hide_user\:[0-9a-z\:]+\]/si", $message) )
         $postrow[$i]['dont_cache'] = 1;
         $sql = "UPDATE " . POSTS_TABLE . "
            SET parsed = 0, dont_cache = 1, cache_file_md5 = NULL
            WHERE post_id = ".$postrow[$i]['post_id'];
         if(!$result = $db->sql_query($sql))
            message_die(GENERAL_ERROR, 'Could not update parse info', '', __LINE__, __FILE__, $sql);
