Easy Mod compatible
Easy Mod compatible
Beitragvon brandsrus » 10. Feb 2007 18:46
I have made the mod EasyMod compatible. Here is the file for easy installation with EM. Replace the whole file and good luck with the installation!
[center][- Codeblock deleted and attachmend added by Admin -][/center]
CPS 1.0.2em.zip
(6.6 KiB) 1305-mal heruntergeladen
brandsrus
Beitragvon AmigaLink » 10. Feb 2007 19:00
THX - I'm no friend of the EasyMOD thus my MODs are not EMC.
(Please don't post files as codeblock! (look at the Boardrules))
Beitragvon brandsrus » 10. Feb 2007 19:09
Oke, but it is very handy for people that installed this mod by Easy Mod. Maybe you can add this file in the place of the other ;)
I'm sorry that i have posted the whole file in the code tags. :oops:
brandsrus
Beitragvon AmigaLink » 10. Feb 2007 19:18
Thanks but I will not do that. Because the EM does not work error free if a board were strongly changed by other MODs.
Therefore I have and will never endorse or even support the EM. (sorry)
