Confirmation code doesnt appear
Beitragvon Anna Carolina » 19. Mär 2009 13:34
Hi people
I need some help First of all sorry my bad english I'm Brazilian
I installed Advanced confirmation code in http://www.tumicse.com.br but the image doesn't appear
My host has gd library installed Can you help me
Thanks
Anna Carolina
Beitragvon oxpus » 19. Mär 2009 16:47
can you please attach your profile.php and usercp_register.php to take a look in them?
Greetings
OXPUS
Ok
Beitragvon Anna Carolina » 19. Mär 2009 18:16
Thanks for your help
phpfiles.zip
(12.74 KiB) 3167-mal heruntergeladen
Anna Carolina
Beitragvon oxpus » 19. Mär 2009 18:56
Hm, the files seems to be okay.
Which GD libary (release number) do you have installed?
Can you see the Captcha images in the ACP in the Captcha Configuration?
Beitragvon Anna Carolina » 19. Mär 2009 19:10
No i can´t see the captcha at the ACP.
Let me check my GD Library version.
Zugefügt nach 5 Minute(n):
Version: 2.0.34
Anna Carolina
Beitragvon oxpus » 19. Mär 2009 22:41
Hm, something may be wrong with the libary.
GD 2.0.0 is needed and yours is newer.
Please contact your hoster.
I've no idea for the moment why the image/catpcha can't be build and displayed...
