AVC error in admin_captcha_config.php on line 25
Beitragvon triple » 13. Mär 2007 03:36
Hallo, thanks for this mod, i finish to install it but when i have access to my admin panel and try to click on CAPTCHA Config appear an error warning:
Warning: main(../public/forum/extension.inc) [function.main]: failed to open stream: No such file or directory in /web/htdocs/www.xxxx.xxx/home/public/forum/admin/admin_captcha_config.php on line 25
Fatal error: main() [function.require]: Failed opening required '../public/forum/extension.inc' (include_path='.:/php/lib/php/') in /web/htdocs/www.xxxx.xxx/home/public/forum/admin/admin_captcha_config.php on line 25
i 've tried to modify line 24 to give the correct root path on admin_captcha_config.php, but i don't know whatb to modify on line 25:
23 // Let's set the root dir for phpBB
24 $phpbb_root_path = '../public/forum/';
25 require($phpbb_root_path . 'extension.inc');
26 require('./pagestart.' . $phpEx);
someone can give me an hand?
thanks!
triple
Beitragvon AmigaLink » 13. Mär 2007 19:50
Normally you must change none path. :roll:
I don't now old boards like yours. :shock: I recommend you update to 2.0.22 :!:
Change the line 24 like that
$phpbb_root_path = "./../";
Mitglieder in diesem Forum: 0 Mitglieder und 22 Gäste
