I can't change the lenguage of the Translate posts Mod
Beitragvon mariocaz » 6. Mai 2006 19:30
Hi my dear friend!! :)
Well I need your preciate help. :P
I have a little problem with the Translate posts Mod, because when I want or any of my users want to change in their Profiles in the Preferences the language of the Translate posts option, they and I can't because when I change the language that I want don't let me save it, so when I return to the Preferences in my Profile to see if I can change the language of the translate posts option, I see that I can't save the change of the language because always appears the language that I put when I register.
Only I can change this if I go to the Admin Panel and to the Admin Users section, there I can do that, because here yes I can save the changes in the translate posts option, so I think this is a little problem since I installed the easyUCP Mod, please take a look of my files and also tell me if u need another one ok. :D
Cheers. :wink:
[center][ Attachment gelöscht am 08.05.2006, 10:17 von AmigaLink ][/center]
Files with the Mod.zip
(26.15 KiB) 1164-mal heruntergeladen
mariocaz
Beitragvon AmigaLink » 8. Mai 2006 09:17
Hello Mario.
Here you have the fixed usercp_register.php :)
fixed usercp_register.php.zip
(16.54 KiB) 1118-mal heruntergeladen
Beitragvon mariocaz » 8. Mai 2006 18:22
Thanx a lot my friend like always!!! :P :D :) :wink:
mariocaz
