hallo amiga
das problem habe ich zwar nicht muss ausgebesstert worden sein
aber anderes prob
das neueste bild mod geht nicht mehr ???
habe nix da .............
kannst mir helfen ???
// Start add - Photo Album Block
'S_COLS' => $album_config['cols_per_page'],
'S_COL_WIDTH' => ( 100/$album_config['cols_per_page'] ) . '%',
'TARGET_BLANK' => ( $album_config['fullpic_popup'] ) ? ' target="_blank"' : '',
'U_ALBUM' => append_sid('album.'.$phpEx),
'L_ALBUM' => $lang['Album'],
'L_NEWEST_PICS' => ( $album_config['pics_sort'] == '0' ) ? $lang['Newest_pics'] : $lang['Random_pics'],
'L_NO_PICS' => $lang['No_Pics'],
'L_PIC_TITLE' => $lang['Pic_Title'],
'L_POSTER' => $lang['Poster'],
'L_POSTED' => $lang['Posted'],
'L_DIMENSION' => $lang['Dimension'],
'L_SIZE' => $lang['Size'],
'L_VIEW' => $lang['View'],
// End add - Photo Album Block
$album_root_path = $phpbb_root_path . 'album_mod/';
include_once($album_root_path . 'album_common.'.$phpEx);
// Build Categories Index
$sql = "SELECT c.*
FROM ". ALBUM_CAT_TABLE ." AS c
LEFT JOIN ". ALBUM_TABLE ." AS p ON c.cat_id = p.pic_cat_id
WHERE cat_id <> 0
GROUP BY cat_id
ORDER BY cat_order ASC";
message_die(GENERAL_ERROR, 'Could not query categories list', '', __LINE__, __FILE__, $sql);
$catrows = array();
$album_user_access = album_user_access($row['cat_id'], $row, 1, 0, 0, 0, 0, 0); // VIEW
if ($album_user_access['view'] == 1)
$catrows[] = $row;
if ( $album_config['pics_all'] == '1' )
$allowed_cat = '0'; // For Recent Public Pics below
$allowed_cat = '';
// $catrows now stores all categories which this user can view. Dump them out!
for ($i = 0; $i < count($catrows); $i++)
// Build allowed category-list (for recent pics after here)
$allowed_cat .= ($allowed_cat == '') ? $catrows[$i]['cat_id'] : ',' . $catrows[$i]['cat_id'];
// Check Pic Approval
if ( ($catrows[$i]['cat_approval'] == ALBUM_ADMIN) || ($catrows[$i]['cat_approval'] == ALBUM_MOD) )
$pic_approval_sql = 'AND p.pic_approval = 1'; // Pic Approval ON
$pic_approval_sql = ''; // Pic Approval OFF
// Recent Public Pics
$pics_allowed = '0';
$pics_allowed = '';
if ( $allowed_cat != $pics_allowed )
$category_id = $album_config['cat_id'];
if ( $album_config['pics_sort'] == '1' )
if ( $category_id != 0 )
$sql = "SELECT p.pic_id, p.pic_title, p.pic_desc, p.pic_user_id, p.pic_user_ip, p.pic_username, p.pic_time, p.pic_cat_id, p.pic_view_count, u.user_id, u.username, u.user_level, r.rate_pic_id, AVG(r.rate_point) AS rating, COUNT(DISTINCT c.comment_id) AS comments, p.pic_filename AS picfilename
FROM ". ALBUM_TABLE ." AS p
LEFT JOIN ". USERS_TABLE ." AS u ON p.pic_user_id = u.user_id
LEFT JOIN ". ALBUM_CAT_TABLE ." AS ct ON p.pic_cat_id = ct.cat_id
LEFT JOIN ". ALBUM_RATE_TABLE ." AS r ON p.pic_id = r.rate_pic_id
LEFT JOIN ". ALBUM_COMMENT_TABLE ." AS c ON p.pic_id = c.comment_pic_id
WHERE p.pic_cat_id IN ($allowed_cat) AND ( p.pic_approval = 1 OR ct.cat_approval = 0 ) AND pic_cat_id IN ($category_id)
GROUP BY p.pic_id
ORDER BY RAND()
LIMIT ". $album_config['pics_number'];
GROUP BY p.pic_id
ORDER BY RAND()
else if ( $album_config['pics_sort'] == '0' )
GROUP BY p.pic_id
ORDER BY pic_time DESC
$sql = "SELECT u.user_level, p.pic_id, p.pic_title, p.pic_desc, p.pic_user_id, p.pic_user_ip, p.pic_username, p.pic_time, p.pic_cat_id, p.pic_view_count, u.user_id, u.username, u.user_level, r.rate_pic_id, AVG(r.rate_point) AS rating, COUNT(DISTINCT c.comment_id) AS comments, p.pic_filename AS picfilename
GROUP BY p.pic_id
message_die(GENERAL_ERROR, 'Could not query recent pics information', '', __LINE__, __FILE__, $sql);
$recentrow = array();
$recentrow[] = $row;
if (count($recentrow) > 0)
for ($i = 0; $i < count($recentrow); $i += $album_config['cols_per_page'])
$template->assign_block_vars('recent_pics', array());
for ($j = $i; $j < ($i + $album_config['cols_per_page']); $j++)
if ( $j >= count($recentrow) )
break;
if (!$recentrow[$j]['rating'])
$recentrow[$j]['rating'] = $lang['Not_rated'];
$recentrow[$j]['rating'] = round($recentrow[$j]['rating'], 2);
// Display pics horizontally
$template->assign_block_vars('recent_pics.recent_col', array(
'U_PIC' => ($album_config['fullpic_popup']) ? append_sid("album_pic.$phpEx?pic_id=". $recentrow[$j]['pic_id']) : append_sid("album_page.$phpEx?pic_id=". $recentrow[$j]['pic_id']),
'THUMBNAIL' => append_sid("album_thumbnail.$phpEx?pic_id=". $recentrow[$j]['pic_id']),
'DESC' => $recentrow[$j]['pic_desc'])
if ( ($recentrow[$j]['user_id'] == ALBUM_GUEST) or ($recentrow[$j]['username'] == '') )
$recent_poster = ($recentrow[$j]['pic_username'] == '') ? $lang['Guest'] : $recentrow[$j]['pic_username'];
// Start add - Username Color Mod
switch ( $recentrow[$j]['user_level'] )
case ADMIN:
$poster_name = '<strong>' . $recentrow[$j]['username'] . '</strong>';
$style_color = ' style="color:# ' . $theme['fontcolor3'] . '"';
break;
case MOD:
$style_color = ' style="color:# ' . $theme['fontcolor2'] . '"';
break;
default:
$poster_name = $recentrow[$j]['username'];
$style_color = '';
break;
// End add - Username Color Mod
$recent_poster = '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&". POST_USERS_URL .'='. $recentrow[$j]['user_id']) . '"' . $style_color . '>' . $poster_name . '</a>';
// Start add - Pics Dimension/Size Add-on
$pic_dimension = getimagesize(ALBUM_UPLOAD_PATH . $recentrow[$j]['picfilename']);
$pic_width = $pic_dimension[0];
$pic_height = $pic_dimension[1];
$pic_size = round(((filesize(ALBUM_UPLOAD_PATH . $recentrow[$j]['picfilename'])) / 1024), 2) . ' ' . $lang['Kb'];
// End add - Pics Dimension/Size Add-on
// Display pics vertically
$template->assign_block_vars('recent_pics.recent_detail', array(
'DESC' => $recentrow[$j]['pic_desc'],
'TITLE' => $recentrow[$j]['pic_title'],
'POSTER' => $recent_poster,
'TIME' => create_date($board_config['default_dateformat'], $recentrow[$j]['pic_time'], $board_config['board_timezone']),
// New entries - Pics Dimension/Size Add-on
'DIMENSION' => $pic_width . ' x ' . $pic_height,
'SIZE' => $pic_size,
'VIEW' => $recentrow[$j]['pic_view_count'],
'RATING' => ($album_config['rate'] == 1) ? ( $lang['Rating'] . ': <a href="' . append_sid("album_rate.$phpEx?pic_id=". $recentrow[$j]['pic_id']) . '">' . $recentrow[$j]['rating'] . '</a><br />') : '',
'COMMENTS' => ($album_config['comment'] == 1) ? ( $lang['Comments'] . ': <a href="' . append_sid("album_comment.$phpEx?pic_id=". $recentrow[$j]['pic_id']) . '">' . $recentrow[$j]['comments'] . '</a>') : '')
// No Pics Found
$template->assign_block_vars('no_pics', array());
// No Cats Found
if ( $CFG['pics_number'] > 0 )
$sql_private_last = ($CFG['pics_all'] == '1') ? '' : ' AND c.cat_user_id = 0';
$sql = "SELECT c.*, COUNT(p.pic_id) AS count
WHERE cat_id <> 0
$sql_private_last
GROUP BY cat_id
$catrows = array();
$catrows[] = $row;
if ( $CFG['pics_all'] == '1' )
$allowed_cat = '';
// Get Last Pic of this Category
if ($catrows[$i]['count'] == 0)
// Category is empty
$last_pic_info = $lang['No_Pics'];
$u_last_pic = '';
$last_pic_title = '';
if ( ($catrows[$i]['cat_approval'] == ALBUM_ADMIN) or ($catrows[$i]['cat_approval'] == ALBUM_MOD) )
// END of Last Pic
$pics_allowed = '';
$CategoryID = $CFG['cat_id'];
if ( $CFG['pics_sort'] == '1' )
if ( $CategoryID != 0 )
$sql = "SELECT p.pic_id, p.pic_title, p.pic_thumbnail, p.pic_desc, p.pic_user_id, p.pic_user_ip, p.pic_username, p.pic_time, p.pic_cat_id, p.pic_view_count, u.user_id, u.username, r.rate_pic_id, AVG(r.rate_point) AS rating, COUNT(DISTINCT c.comment_id) AS comments
WHERE p.pic_cat_id IN ($allowed_cat) AND ( p.pic_approval = 1 OR ct.cat_approval = 0 ) AND pic_cat_id IN ($CategoryID)
GROUP BY p.pic_id
ORDER BY RAND()
LIMIT ". $CFG['pics_number'];
GROUP BY p.pic_id
ORDER BY RAND()
else if ( $CFG['pics_sort'] == '0' )
GROUP BY p.pic_id
GROUP BY p.pic_id
break;
$pic_size = @getimagesize(ALBUM_CACHE_PATH . $recentrow[$j]['pic_thumbnail']);
$pic_width = $pic_size[0];
$pic_height = $pic_size[1];
if ($pic_width > $pic_height)
$width = $CFG['pics_thumbsize'];
$height = $CFG['pics_thumbsize'] * ($pic_height/$pic_width);
else if ($pic_width < $pic_height)
$height = $CFG['pics_thumbsize'];
$width = $CFG['pics_thumbsize'] * ($pic_width/$pic_height);
$width = '90%';
$height = '90%';
'U_PIC' => ($album_config['fullpic_popup']) ? append_sid("album_pic.$phpEx?pic_id=". $recentrow[$j]['pic_id']) : append_sid("album_showpage.$phpEx?pic_id=". $recentrow[$j]['pic_id']),
'WIDTH' => $width,
'HEIGHT' => $height,
if( ($recentrow[$j]['user_id'] == ALBUM_GUEST) or ($recentrow[$j]['username'] == '') )
$recent_poster = '<a href="'. append_sid("profile.$phpEx?mode=viewprofile&". POST_USERS_URL .'='. $recentrow[$j]['user_id']) .'">'. $recentrow[$j]['username'] .'</a>';
'WIDTH' => $width,
'RATING' => ($album_config['rate'] == 1) ? ( $lang['Rating'] . ': ' . $recentrow[$j]['rating'] . '<br />') : '',
'COMMENTS' => ($album_config['comment'] == 1) ? ( $lang['Comments'] . ': ' . $recentrow[$j]['comments'] . '<br />') : '')
// No Pics Found
$template->assign_block_vars('switch_album_pic', array());
