## MOD Title: Change Forum Index Images
## MOD Author: Minc
## MOD Description: Gives you the possibility to define an image for every forum
## MOD Version: 1.0
## Installation Level: easy
## Installation Time: 3 Minutes
## Files To Edit: 2
## Included Files: n/a
## Generator: phpBB2 Mod Maker 0.1.67
## See http://smartor.is-root.com/viewtopic.php?t=14365 for details
## Create icons for every forum and place them into the templates' image-folder.
## In this example, the files should be named:
## The starting number is the Forum-ID.
## For every template, do:
templates/subSilver/subSilver.cfg
$images['forum'] = "$current_template_images/folder_big.gif";
$images['forum'] = "$current_template_images/";
index.php
'L_FORUM_FOLDER_ALT' => $folder_alt,
'FORUM_ID' => $forum_id,
templates/subSilver/index_body.tpl
<td class="row1" align="center" valign="middle" height="50"><img src="{catrow.forumrow.FORUM_FOLDER_IMG}" width="46" height="25" alt="{catrow.forumrow.L_FORUM_FOLDER_ALT}" title="{catrow.forumrow.L_FORUM_FOLDER_ALT}" /></td>
<td class="row1" align="center" valign="middle" height="50"><img src="{catrow.forumrow.FORUM_FOLDER_IMG}{catrow.forumrow.FORUM_ID}folder_big.gif" width="46" height="25" alt="{catrow.forumrow.L_FORUM_FOLDER_ALT}" title="{catrow.forumrow.L_FORUM_FOLDER_ALT}" /></td>
AmigaLink hat geschrieben: @ Max
Bitte den code-tag, für codes, benutzen und nicht den quote!
(Ich hab das jetzt geändert)
