Fadeing the button from Change Poster MOD
Beitragvon mariocaz » 22. Jun 2005 21:01
My friend another favor. :oops:
How Can I do for make to this icon ("icon_user") fade in the posts like the others icons (quote, delete, edit, etc.) ??? :?
Here is my viewtopic.php file (just in case you need it) with the MOD and the correction that I put here. :wink:
Thanx for all the attentions that you have with me. :P
Added after 20 hours 30 minutes:
Thank yoy Amigalink for move this post here! :P
I wait for your help.
viewtopic.zip
(16.06 KiB) 1479-mal heruntergeladen
mariocaz
Beitragvon AmigaLink » 22. Jun 2005 21:16
This effect will come through a MOD like Fading Buttons. I think in your board is a similarly MOD that was placed in the .tpl files. Therefore look at your viewtopic_body.tpl to see how it will be made by the other images.
Beitragvon mariocaz » 23. Jun 2005 00:10
Hi Amigalink!!
Here are my .tpl files
Thanx for always help me. :D
Added after 2 hours 20 minutes:
Amigalink here is the bug solved!!!
Thanx my friend and also thanx to my friens oxpus, really you are a genios in this!! :mrgreen:
oxpus - Thu 23.Jun, 2005 00:51";p="36509 hat geschrieben:Okay.
On fiblue3d.cfg find the line
$images['icon_user'] = "$current_template_images/{LANG}/icon_user.gif";
(at the end) and replace this with
$images['icon_user'] = "$current_template_images/{LANG}/icon_user.gif" class="imgfade" " . "$ifade";
and on fisubsilversh.cfg do the same.
At least replace the image itself with a better one and enjoy.
[center][ Attachment gelöscht am 23.06.2005, 02:36 von AmigaLink ][/center]
mariocaz
Beitragvon AmigaLink » 23. Jun 2005 01:37
Thx for the info
