Double post merge MOD (Problem with the SQL instruction)
Beitragvon mariocaz » 18. Jun 2005 17:40
Hello there!!! :D
I saw that here is installed this very good MOD 8) and I want to install this MOD to my forum, but the SQL instrucion is wrong, because when I try to run it it appears an error in the phpMyAdmin.
Also I tried to run the double_post_merge_mod_install.php, but the same thing, appears an error.
I attach here the file(MOD) that I downloaded for check that. :P
I wait your answer for install it, please help me!. :oops:
Regards, :wink:
Mario
[center][ Attachment gelöscht am 13.07.2005, 09:49 von AmigaLink ][/center]
mariocaz
Beitragvon AmigaLink » 18. Jun 2005 19:32
Take this:
INSERT INTO phpbb_config (config_name, config_value) VALUES ('join_interval', '18');
You must look at the phpbb_ in front of the tablename. Some Admins have change this and forget to adapt it in there installation guides.
Beitragvon mariocaz » 18. Jun 2005 20:35
Thanx my friend, this MOD is really fine!
mariocaz
Beitragvon AmigaLink » 18. Jun 2005 21:10
I think so too. :)
In future i will write an addon for it. So that it can be configure for each forum and disable by admin / mods wile posting. :D
Beitragvon mariocaz » 18. Jun 2005 21:54
WWooww that's will be great!!!
And I will the first person for install it. :D
mariocaz
Beitragvon khaledelmansoury » 11. Aug 2005 13:11
mariocaz hat geschrieben:WWooww that's will be great!!!
And I will the second person that install it. :lol:
khaledelmansoury
Beitragvon AmigaLink » 27. Nov 2005 22:36
http://www.amigalink.de/viewtopic.php?t=422#2648 :)
Configuration for each forum will be come later!
Mitglieder in diesem Forum: Majestic-12 [Bot] und 2 Gäste
