Where Can I find this MOD ??
Beitragvon mariocaz » 15. Jun 2005 22:04
Hi Amigalink! :D
First forgive me if this place is not the apropeated to post this. :oops:
I'm again Mario from Mexico. :wink:
I'm trying to find this MOD Quicklinks and I can't download from here I don't know why? :cry:
http://www.amigalink.de/download ... d=48&cat=3
I want it because with this MOD(Quicklinks) I will complement the great Lexicon MOD in my forum. :P
I really need it please if you have it tell me or tell me where can I find it because I searched in other sites like the site of the author (is unavailable), oxpus.de(download unavailable), phpbb.com, phpbb.de, phpbb2.de, phphacks.com, also in google and anyone have it. :?
Help me please! :(
mariocaz
Beitragvon AmigaLink » 16. Jun 2005 11:45
Hi Mario.
Here you can't download because you havent enough postings on amigalink.de. The minimum of posts, to download the mods those not written by me, is set to 25. And by oxpus it is the same.
Otherwise quicklinks ist only avalable on the development-board of the autor. And this seems to be down in the moment. :(
But i will send you a mail with the mod. :D
Thank you! :P
Greetings ... AmigaLink
Zugefügt nach 4 Minute(n):
The e-mail ist on the way. :D
Beitragvon mariocaz » 16. Jun 2005 16:06
Thanks a lot my friend, I recieved your mail with the File of the MOD. :D
I will try to install it and I tell you the result. :wink:
Thanx again, :)
Mario
mariocaz
Beitragvon AmigaLink » 16. Jun 2005 21:03
No problem! :)
Zugefügt nach 1 Minute(n):
I am very interested on the result of the combination of those MODs. :)
Beitragvon mariocaz » 17. Jun 2005 01:36
Hi my friend!!!
I have just installed the MOD, but one problem... the Mod works perfectly but only change simple words to links not compound words and I really need very much to convert compound words in links because in the Lexicon almost all the words are compound.
Example that I need to change words like this in links:
Amigalink forum, Robbie Williams
Not convert only Amigalink or Robbie.
Because If I put in the Quicklinks MOD in the ACP, Robbie Williams nothing happen in the convertion.
I believe is a little fix because the Word Censor MOD works with simple and also compound words.
Can you help me to fix this ???
Regards,
Mario
Added after 3 hours 26 minutes:
I don't know why but htat problem is fix it !!! :shock: ... Good News for me jejeje 8)
Only one thing... tell me if you know what can I do for fix that always in the URL option is the URL of the forum and if I put another URL different like the forum don't show the URL that I want. (error in the browse).
Example:
If I put in the ACP (Quicklinks): www.phpbb.com
In the topic the word-link is: www.oxpus.de/www.phpbb.com
Because If I want to put another URL different than the forum I can't. :cry:
And I don't know how to fix it. :?
And If I can open the URL of the link-word in a New Window, much better.
mariocaz
Beitragvon AmigaLink » 17. Jun 2005 11:26
Why www.oxpus.de ??? :shock:
If you set a link to a site that is not yours (e.g. www.phpbb.com) you must write http://www.phpbb.com!
Al links without http: will see as a local link, so that they become the name of your server in front of the URL.
Beitragvon mariocaz » 17. Jun 2005 21:40
AmigaLink hat geschrieben:In the topic the word-link is: www.oxpus.de/www.phpbb.com
Jejejeje I said is only an EXAMPLE for explain you :wink:
Ok thank you I see if I put antoher site different of my forum I have to put http:// ... And that works!!! :D
Ok now what can I do for the link of the word open in a new browse(window) ? :?
Thank you very much my friend this MOD is excellent and in combination with the Lexicon MOD is more excellent. :P
Added after 5 hours 21 minutes:
Thank you very much, I also fix that problem.
Now all works very nice.
Regards,
Mario from Mexico
mariocaz
Beitragvon AmigaLink » 17. Jun 2005 23:51
Nice to read that. :)
Beitragvon mariocaz » 18. Jun 2005 18:30
Yeah yeah is great !!! :mrgreen:
mariocaz
Mitglieder in diesem Forum: 0 Mitglieder und 37 Gäste
