klar weil  <!-- BEGIN reg_user_row --> davor ist, es muss also unterhalb in der admim/index.php gemacht werden.
Versuchs mal hiermit also:
- Code: Alles auswählen
 admin/index.php
 $template->assign_block_vars("reg_user_row", array(
 "ROW_COLOR" => "#" . $row_color,
 "ROW_CLASS" => $row_class,
 "USERNAME" => $username,
 "STARTED" => create_date($board_config['default_dateformat'], $onlinerow_reg[$i]['session_start'], $board_config['board_timezone']),
 "LASTUPDATE" => create_date($board_config['default_dateformat'], $onlinerow_reg[$i]['user_session_time'], $board_config['board_timezone']),
 "FORUM_LOCATION" => $location,
 "IP_ADDRESS" => $reg_ip,
 "U_WHOIS_IP" => "http://network-tools.com/default.asp?host=$reg_ip",
 "U_USER_PROFILE" => append_sid("admin_users.$phpEx?mode=edit&" . POST_USERS_URL . "=" . $onlinerow_reg[$i]['user_id']),
 "U_FORUM_LOCATION" => append_sid($location_url))
 if ($userdata['user_level'] == ADMIN)
 $template->assign_block_vars('switch_admin_logged_in', array());
 $template->assign_block_vars("guest_user_row", array(
 "USERNAME" => $lang['Guest'],
 "STARTED" => create_date($board_config['default_dateformat'], $onlinerow_guest[$i]['session_start'], $board_config['board_timezone']),
 "LASTUPDATE" => create_date($board_config['default_dateformat'], $onlinerow_guest[$i]['session_time'], $board_config['board_timezone']),
 "IP_ADDRESS" => $guest_ip,
 "U_WHOIS_IP" => "http://network-tools.com/default.asp?host=$guest_ip",
Und in der TPL Datei es dann noch einfügen:
 templates/subSilver/admin/index_body.tpl
 <td width="20%" class="{reg_user_row.ROW_CLASS}"> <span class="gen"><a href="{reg_user_row.U_USER_PROFILE}" class="gen">{reg_user_row.USERNAME}</a></span> </td>
 <td width="20%" align="center" class="{reg_user_row.ROW_CLASS}"> <span class="gen">{reg_user_row.STARTED}</span> </td>
 <td width="20%" align="center" nowrap="nowrap" class="{reg_user_row.ROW_CLASS}"> <span class="gen">{reg_user_row.LASTUPDATE}</span> </td>
 <td width="20%" class="{reg_user_row.ROW_CLASS}"> <span class="gen"><a href="{reg_user_row.U_FORUM_LOCATION}" class="gen">{reg_user_row.FORUM_LOCATION}</a></span> </td>
 <td width="20%" class="{reg_user_row.ROW_CLASS}"> <span class="gen"><a href="{reg_user_row.U_WHOIS_IP}" class="gen" target="_phpbbwhois">{reg_user_row.IP_ADDRESS}</a></span> </td>
 <!-- END reg_user_row -->
 #-----[ REPLACE WHIT ]----------------------------------------------------------
 <!-- BEGIN switch_admin_logged_in -->
 <td width="20%" class="{reg_user_row.ROW_CLASS}"> <a href="{reg_user_row.U_WHOIS_IP}" target="_phpbbwhois">{reg_user_row.IP_ADDRESS}</a> </td>
 <!-- END switch_admin_logged_in -->
 <!-- BEGIN guest_user_row -->
 <td width="20%" class="{guest_user_row.ROW_CLASS}"> <span class="gen">{guest_user_row.USERNAME}</span> </td>
 <td width="20%" align="center" class="{guest_user_row.ROW_CLASS}"> <span class="gen">{guest_user_row.STARTED}</span> </td>
 <td width="20%" align="center" nowrap="nowrap" class="{guest_user_row.ROW_CLASS}"> <span class="gen">{guest_user_row.LASTUPDATE}</span> </td>
 <td width="20%" class="{guest_user_row.ROW_CLASS}"> <span class="gen"><a href="{guest_user_row.U_FORUM_LOCATION}" class="gen">{guest_user_row.FORUM_LOCATION}</a></span> </td>
 <td width="20%" class="{guest_user_row.ROW_CLASS}"> <span class="gen"><a href="{guest_user_row.U_WHOIS_IP}" target="_phpbbwhois">{guest_user_row.IP_ADDRESS}</a></span> </td>
 <!-- END guest_user_row -->
Sollte es dann nicht gehen, dann nehme bei die index_body.tpl Datei statt die REPLACE WHIT Teile diese möglichkeit, aber dann sollte es eigentlich gehen.
-   <!-- BEGIN reg_user_row -->
 <td width="20%" class="{reg_user_row.ROW_CLASS}"> <a href="{reg_user_row.U_WHOIS_IP}" target="_phpbbwhois">{reg_user_row.switch_admin_logged_in.IP_ADDRESS}</a> </td>
 und für des Guest teil
-   <!-- BEGIN guest_user_row -->
 <td width="20%" class="{guest_user_row.ROW_CLASS}"> <span class="gen"><a href="{guest_user_row.U_WHOIS_IP}" target="_phpbbwhois">{guest_user_row.switch_admin_logged_in.IP_ADDRESS}</a></span> </td>
Sollte es dann immer noch nicht gehen, dann dürfte $userdata in der PHP Datei ohne Funktion sein, was ich mir aber ehrlich gesagt nicht vorstellen kann.
