Difference in the new download of the Chang Poster Mod Fix #5 ?
Beitragvon mariocaz » 6. Apr 2007 20:31
Hi my friend Amigalink, ;)
I only want to know which is the difference in the new download (Fix #5) of this Mod that you recently put it here with the original Mod ?
Because I don't know if I have that Fix did it in my Change Poster Mod that I have installed in my forum and what I have to do for this update ?, because in the instructions don't say anything about that. :(
Regards,
Mario
mariocaz
Beitragvon AmigaLink » 7. Apr 2007 09:19
Sorry I don't know the difference between the particular Versions (1.0-Fix #5 is the original MOD). It's to long ago that I have install the update.
But I can say that this version include a bug. If you install it you musst install my fix too. http://www.amigalink.de/viewtopic.php?t=907
Beitragvon mariocaz » 7. Apr 2007 17:22
Mmmm I think I have installed the Mod Ver. 1.0 because also I didn't find any of the Code that you put in the other post. :?
To do the installation of the Mod Fix #5 I have to do a clean installation ?, or do you know what I have to do for the upgrade ? :D
mariocaz
Beitragvon AmigaLink » 7. Apr 2007 18:02
Do a clean installation.
