Double post merge compatible with Prevent All Caps Mod
Beitragvon mariocaz » 4. Apr 2007 06:58
Hi Amigalink!!!
How are you my friend ? :)
Well sometime ago you recommend me this Mod "Double Post Merge" and today I installed this little great Mod "Prevent All Caps Mod" in my forum. ;)
www.all-reefs.com
But I hae a little problem because when I merge one post the Prevent All Caps Mos is not working :cry: , only is working with the subjects and if I put a normal post without merge it with another.
So I want to know if you can help me with this little problem, I hope you can. :D
Cheers,
Mario
[center][ Attachment gelöscht am 04.04.2007, 19:22 von AmigaLink ][/center]
Prevent All Caps Posts.zip
(1.57 KiB) 1487-mal heruntergeladen
mariocaz
Beitragvon AmigaLink » 4. Apr 2007 12:28
Hello Mario
Works the 'Prevent All Caps' when you edit a post?
Beitragvon mariocaz » 4. Apr 2007 17:19
Noup, also is not working when I edit a post. :?
mariocaz
Beitragvon AmigaLink » 5. Apr 2007 17:25
Shit MOD. :?
But anyway its a mistake in reasoning by me. The Problem is not the edit function (although the merge will be a edit). The problem is the text which will be inserted by the 'Double post merge'. This text is with small letters, so the 'Prevent All Caps' will be works correctly. ;)
Beitragvon mariocaz » 5. Apr 2007 18:46
Okidoki my friend, ;)
So I have to wait a little for some coda that you will give me ?, I think so. :D :idea:
Jejeje so sorry but I don't understand you very very well. :oops:
mariocaz
Beitragvon AmigaLink » 5. Apr 2007 20:44
I know my english is not so good. :?
I do not plan to code something. Because I have no idea to solve the problem.
Beitragvon mariocaz » 5. Apr 2007 20:56
Mmmm ok my friend, don't worry!
Anyway thank you a lot for all your nice help in this.
And if some moment you think in a solution please tell me ok. ;)
mariocaz
Beitragvon AmigaLink » 5. Apr 2007 21:42
Promised :)
