easyUCP mit AVC MOD
easyUCP mit AVC MOD
Beitragvon Christian_N » 31. Aug 2006 14:04
Hallo Amigalink,
hab gerade den AVC eingebaut auf ne testseite wo der easyUCP MOD installiert ist, da fiel mir allerdings auf das die änderrung in der usercp_register.php
      $code = dss_rand();
      $code_length = mt_rand(4, 6);
      $code = dss_rand();
      $code = strtoupper(base_convert($code, 16, 35));
      $code = substr($code, 2, $code_length);
nichts bringen, da dieser teil vom VC kompett vom easyUCP /* auskommentiert */ wurde und etwas oben der easyUCP MOD diese einsetzt
   if ( $ucp_mode == 'ucp_require' || $ucp_mode == '' )
      $template->assign_block_vars('switch_ucp_require', array() );
      if ( $mode == 'editprofile' )
         $template->assign_block_vars('switch_ucp_require.switch_edit_profile', array());
      if ( ($mode == 'register') || ($board_config['allow_namechange']) )
         $template->assign_block_vars('switch_ucp_require.switch_namechange_allowed', array());
         $template->assign_block_vars('switch_ucp_require.switch_namechange_disallowed', array());
         // Visual Confirmation
         $confirm_image = '';
         if (!empty($board_config['enable_confirm']) && $mode == 'register')
            $sql = 'SELECT session_id
               FROM ' . SESSIONS_TABLE;
               $confirm_sql = '';
               do
               $sql = 'DELETE FROM ' .  CONFIRM_TABLE . "
               if (!$db->sql_query($sql))
            $db->sql_freeresult($result);
            $sql = 'SELECT COUNT(session_id) AS attempts
               WHERE session_id = '" . $userdata['session_id'] . "'";
               message_die(GENERAL_ERROR, 'Could not obtain confirm code count', '', __LINE__, __FILE__, $sql);
               if ($row['attempts'] > 3)
                  message_die(GENERAL_MESSAGE, $lang['Too_many_registers']);
            mt_srand($sec * $usec);
            $code = '';
            for ($i = 0; $i < 6; $i++)
            unset($code);
            $confirm_image = (@extension_loaded('zlib')) ? '<img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id") . '" alt="" title="" />' : '<img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id&amp;c=1") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id&amp;c=2") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id&amp;c=3") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id&amp;c=4") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id&amp;c=5") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id&amp;c=6") . '" alt="" title="" />';
            $template->assign_block_vars('switch_ucp_require.switch_confirm', array());
Nur da ist die Zeile die gefunden werden soll nicht dabei, um diese zu ersetzen, somit zeigt er auch des I weiter an und es variiert nicht der Code. Daher die frage was kann man genau bei dem im easyUCP alles ändern damit der AVC auch 100% läuft?
Beitragvon AmigaLink » 31. Aug 2006 14:36
Ich muss die Installationsanleitung des easyUCP mal ans aktuelle 2.0.21 anpassen. :roll: (Leider fehlt die Zeit für sowas.)
Der vom easyUCP Auskommentierte VC Teil wird an anderer stelle wieder eingesetzt (das ist der von die gepostete Teil). Der wieder eingesetzt Code ist aber noch der des phpBB 2.0.18 und muss somit erstmal auf den aktuellen upgedatet werden. ;)
includes/usercp_register.php
               $confirm_sql = '';
               do
            $code = '';
            unset($code);
               $confirm_sql = '';
               do
            $code = dss_rand();
            unset($code);
Wer den easyUCP bereits drin hatte, als er sein Board upgedatet hat. Müsste das Automatisch richtig gemacht haben.
Aber wer, so wie du, den easyUCP erst später eingebaut hat. Hat da evtl. ein kleines Problem. Es sei denn derjenige hat soviel Erfahrung das ihm der Unterschied auffällt.
Beitragvon Christian_N » 31. Aug 2006 15:09
Danke, das wollt ich nur wissen, so dumm bin ich auch nicht und hab etwas erfahrung, hab auch deshalb schonmal vorweg den teil aus dem auskommentiertes kopiert und in den teil vom easyUCP eingesetzt, so 1:1 also, und dann dort die änderrung vom AVC MOD gemacht. sieht jetzt so aus
         $confirm_sql = '';
         do
      $code = dss_rand();
      unset($code);
      $confirm_image = '<img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id") . '" alt="" title="" />';
Wenn ich jetzt dein Code anschaun dürfte es sogar so richtig sein, wollt allerdings nur auf ne nummer sicher gehn :)
Wobei ich im gesatz zu dein code auch noch die reihe
in
habe da so es auch im normale VC ist und wenn man so Add-ONs anschaun hier wo immermal gefragt wird falls diese ein VC nutzt wie login .php durch CT v. =< 4 oder bei Guest posting etc. das dann immer auch diese änderrung mir auffiel dort :D
Zugefügt nach 1 Minute(n):
Naja das mit dem anpasse, ist schon so eine sache wenn man die Zeit nicht zu hat, irgendwoher kenn ich es nur allzu gut :D Aba in der neue version ist es sicher angepasst falls dann nicht phpBB sich irgendwelche änderrung wieder einfallen lassen :o
Beitragvon AmigaLink » 31. Aug 2006 20:26
Ja, das ist vollkommen richtig so. :)
Der Code den ich gepostet habe, war generell noch ohne AVC Änderung. Schließlich ist es ein easyUCP update. ;)
Mitglieder in diesem Forum: 0 Mitglieder und 25 Gäste
