phpbb 2.0.10 update to 2.0.11 and visual confirmation
Beitragvon mgutt » 21. Nov 2004 15:25
das sind die Installationsschritte von dem genannten update.
Leider funktioniert die Visual Confirmation nicht. (trotz aktivierung im admin-panel)
Ich denke, dass liegt an den Änderungen in der usercp_register.php, aber ich weiß nicht was ich da ändern muss.
wäre super, wenn du schnell helfen könntest.
die änderungen in der profile_add_body.tpl sind ja bereits seit 2.0.10 inkludiert und die switches sehen richtig aus.
phpBB 2.0.10 to phpBB 2.0.11 Code Changes
These are the Changes from phpBB 2.0.10 to phpBB 2.0.11 summed up into a little Mod. This might be very helpful if you want to update your Board and have installed a bunch of Mods. Then it's normally easier to apply the Code Changes than to install all Mods again.
When you find a 'AFTER, ADD'-Statement, the Code have to be added after the last line quoted in the 'FIND'-Statement.
When you find a 'BEFORE, ADD'-Statement, the Code have to be added before the first line quoted in the 'FIND'-Statement.
When you find a 'REPLACE WITH'-Statement, the Code quoted in the 'FIND'-Statement have to be replaced completely with the quoted Code in the 'REPLACE WITH'-Statement.
When you find a 'DELETE'-Statement, the Code have to be deleted.
After you have finished this tutorial, you have to upload the update_to_2011.php file, execute it and then delete it from your webspace.
Ok, lets start:
The first step to do, is to upload the new file usercp_confirm.php to your includes folder:
copy usercp_confirm.php to includes/usercp_confirm.php
The two files can be found within the phpBB Archive itself.
  • admin/admin_board.php
  1. FIND - Line 100
    $activation_user = ( $new['require_activation'] == USER_ACTIVATION_SELF ) ? "checked=\"checked\"" : "";
    $activation_admin = ( $new['require_activation'] == USER_ACTIVATION_ADMIN ) ? "checked=\"checked\"" : "";
    AFTER, ADD
    $confirm_yes = ($new['enable_confirm']) ? 'checked="checked"' : '';
    $confirm_no = (!$new['enable_confirm']) ? 'checked="checked"' : '';
  2. FIND - Line 166
       "L_NONE" => $lang['Acc_None'],
       "L_USER" => $lang['Acc_User'],
       "L_ADMIN" => $lang['Acc_Admin'],
    AFTER, ADD
       "L_VISUAL_CONFIRM" => $lang['Visual_confirm'],
       "L_VISUAL_CONFIRM_EXPLAIN" => $lang['Visual_confirm_explain'],
  • common.php
  1. FIND - Line 28
    function unset_vars(&$var)
       while (list($var_name, $null) = @each($var))
          unset($GLOBALS[$var_name]);
       return;
    error_reporting  (E_ERROR | E_WARNING | E_PARSE); // This will NOT report uninitialized variables
    set_magic_quotes_runtime(0); // Disable magic_quotes_runtime
    $ini_val = (@phpversion() >= '4.0.0') ? 'ini_get' : 'get_cfg_var';
    // Unset globally registered vars - PHP5 ... hhmmm
    if (@$ini_val('register_globals') == '1' || strtolower(@$ini_val('register_globals')) == 'on')
       $var_prefix = 'HTTP';
       $var_suffix = '_VARS';
       $test = array('_GET', '_POST', '_SERVER', '_COOKIE', '_ENV');
       foreach ($test as $var)
          if (is_array(${$var_prefix . $var . $var_suffix}))
             unset_vars(${$var_prefix . $var . $var_suffix});
             @reset(${$var_prefix . $var . $var_suffix});
          if (is_array(${$var}))
             unset_vars(${$var});
             @reset(${$var});
       if (is_array(${'_FILES'}))
          unset_vars(${'_FILES'});
          @reset(${'_FILES'});
       if (is_array(${'HTTP_POST_FILES'}))
          unset_vars(${'HTTP_POST_FILES'});
          @reset(${'HTTP_POST_FILES'});
    // PHP5 with register_long_arrays off?
    if (!isset($HTTP_POST_VARS) && isset($_POST))
       $HTTP_POST_VARS = $_POST;
       $HTTP_GET_VARS = $_GET;
       $HTTP_SERVER_VARS = $_SERVER;
       $HTTP_COOKIE_VARS = $_COOKIE;
       $HTTP_ENV_VARS = $_ENV;
       $HTTP_POST_FILES = $_FILES;
    REPLACE WITH
    // The following code (unsetting globals) was contributed by Matt Kavanagh
       // _SESSION is the only superglobal which is conditionally set
       if (isset($_SESSION))
          $HTTP_SESSION_VARS = $_SESSION;
    if (@phpversion() < '4.0.0')
       // PHP3 path; in PHP3, globals are _always_ registered
       // We 'flip' the array of variables to test like this so that
       // we can validate later with isset($test[$var]) (no in_array())
       $test = array('HTTP_GET_VARS' => NULL, 'HTTP_POST_VARS' => NULL, 'HTTP_COOKIE_VARS' => NULL, 'HTTP_SERVER_VARS' => NULL, 'HTTP_ENV_VARS' => NULL, 'HTTP_POST_FILES' => NULL);
       // Loop through each input array
       @reset($test);
       while (list($input,) = @each($test))
          while (list($var,) = @each($$input))
             // Validate the variable to be unset
             if (!isset($test[$var]) && $var != 'test' && $var != 'input')
                unset($$var);
    else if (@ini_get('register_globals') == '1' || strtolower(@ini_get('register_globals')) == 'on')
       // PHP4+ path
       // Not only will array_merge give a warning if a parameter
       // is not an array, it will actually fail. So we check if
       // HTTP_SESSION_VARS has been initialised.
       if (!isset($HTTP_SESSION_VARS))
          $HTTP_SESSION_VARS = array();
       // Merge all into one extremely huge array; unset
       // this later
       $input = array_merge($HTTP_GET_VARS, $HTTP_POST_VARS, $HTTP_COOKIE_VARS, $HTTP_SERVER_VARS, $HTTP_SESSION_VARS, $HTTP_ENV_VARS, $HTTP_POST_FILES);
       unset($input['input']);
       while (list($var,) = @each($input))
          unset($$var);
       unset($input);
  • groupcp.php
  1. FIND - Line 475
                $username = ( isset($HTTP_POST_VARS['username']) ) ? htmlspecialchars($HTTP_POST_VARS['username']) : '';
    REPLACE WITH
                $username = ( isset($HTTP_POST_VARS['username']) ) ? phpbb_clean_username($HTTP_POST_VARS['username']) : '';
  • includes/constants.php
  1. FIND - Line 151
    // Table names
    AFTER, ADD
    define('CONFIRM_TABLE', $table_prefix.'confirm');
  • includes/functions.php
  1. FIND - Line 80
    // Get Userdata, $user can be username or user_id. If force_str is true, the username will be forced.
    BEFORE, ADD
    // added at phpBB 2.0.11 to properly format the username
    function phpbb_clean_username($username)
       $username = htmlspecialchars(rtrim(trim($username), "\\"));
       $username = substr(str_replace("\\'", "'", $username), 0, 25);
       $username = str_replace("'", "\\'", $username);
       return $username;
  2. FIND - Line 96
          $user = trim(htmlspecialchars($user));
          $user = substr(str_replace("\\'", "'", $user), 0, 25);
          $user = str_replace("'", "\\'", $user);
    REPLACE WITH
          $user = phpbb_clean_username($user);
  • includes/functions_post.php
  1. FIND - Line 131
          $username = trim(strip_tags($username));
    REPLACE WITH
          $username = phpbb_clean_username($username);
  • includes/functions_search.php
  1. FIND - Line 438
          $username_search = preg_replace('/\*/', '%', trim(strip_tags($search_match)));
    REPLACE WITH
          $username_search = preg_replace('/\*/', '%', phpbb_clean_username($search_match));
  2. FIND - Line 472
          'USERNAME' => ( !empty($search_match) ) ? strip_tags($search_match) : '',
    REPLACE WITH
          'USERNAME' => (!empty($search_match)) ? phpbb_clean_username($search_match) : '',
  • includes/topic_review.php
  1. FIND - Line 33
          if ( !isset($topic_id) )
             message_die(GENERAL_MESSAGE, 'Topic_not_exist');
    REPLACE WITH
          if ( !isset($topic_id) || !$topic_id)
             message_die(GENERAL_MESSAGE, 'Topic_post_not_exist');
  • includes/usercp_register.php
  1. FIND - Line 24
    AFTER, ADD
       This code has been modified from its original form by psoTFX @ phpbb.com
       Changes introduce the back-ported phpBB 2.2 visual confirmation code.
       NOTE: Anyone using the modified code contained within this script MUST include
       a relevant message such as this in usercp_register.php ... failure to do so
       will affect a breach of Section 2a of the GPL and our copyright
       png visual confirmation system : (c) phpBB Group, 2003 : All Rights Reserved
  2. FIND - Line 112
       $strip_var_list = array('username' => 'username', 'email' => 'email', 'icq' => 'icq', 'aim' => 'aim', 'msn' => 'msn', 'yim' => 'yim', 'website' => 'website', 'location' => 'location', 'occupation' => 'occupation', 'interests' => 'interests');
    AFTER, ADD
       $strip_var_list['confirm_code'] = 'confirm_code';
  3. FIND - Line 269
             $error_msg .= ( ( isset($error_msg) ) ? '<br />' : '' ) . $lang['Fields_empty'];
    AFTER, ADD
       if ($board_config['enable_confirm'] && $mode == 'register')
          if (empty($HTTP_POST_VARS['confirm_id']))
             $error = TRUE;
             $error_msg .= ( ( isset($error_msg) ) ? '<br />' : '' ) . $lang['Confirm_code_wrong'];
             $confirm_id = htmlspecialchars($HTTP_POST_VARS['confirm_id']);
             if (!preg_match('/^[A-Za-z0-9]+$/', $confirm_id))
                $confirm_id = '';
             $sql = 'SELECT code
                FROM ' . CONFIRM_TABLE . "
                WHERE confirm_id = '$confirm_id'
                   AND session_id = '" . $userdata['session_id'] . "'";
                message_die(GENERAL_ERROR, 'Could not obtain confirmation code', __LINE__, __FILE__, $sql);
                if ($row['code'] != $confirm_code)
                   $error = TRUE;
                   $sql = 'DELETE FROM ' . CONFIRM_TABLE . "
                   if (!$db->sql_query($sql))
                      message_die(GENERAL_ERROR, 'Could not delete confirmation code', __LINE__, __FILE__, $sql);
                $error = TRUE;
             $db->sql_freeresult($result);
  4. FIND - Line 903
          $template->assign_block_vars('switch_namechange_disallowed', array());
    AFTER, ADD
       // Visual Confirmation
       $confirm_image = '';
       if (!empty($board_config['enable_confirm']) && $mode == 'register')
          $sql = 'SELECT session_id
             FROM ' . SESSIONS_TABLE;
             $confirm_sql = '';
             do
          $sql = 'SELECT COUNT(session_id) AS attempts
             WHERE session_id = '" . $userdata['session_id'] . "'";
             message_die(GENERAL_ERROR, 'Could not obtain confirm code count', '', __LINE__, __FILE__, $sql);
             if ($row['attempts'] > 3)
                message_die(GENERAL_MESSAGE, $lang['Too_many_registers']);
          mt_srand($sec * $usec);
          $code = '';
          for ($i = 0; $i < 6; $i++)
          unset($code);
          $confirm_image = (@extension_loaded('zlib')) ? '<img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id") . '" alt="" title="" />' : '<img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id&amp;c=1") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id&amp;c=2") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id&amp;c=3") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id&amp;c=4") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id&amp;c=5") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&amp;id=$confirm_id&amp;c=6") . '" alt="" title="" />';
  5. FIND - Line 993
          'NEW_PASSWORD' => $new_password,
          'PASSWORD_CONFIRM' => $password_confirm,
          'EMAIL' => $email,
    AFTER, ADD
          'CONFIRM_IMG' => $confirm_image,
  6. FIND - Line 1087
          'L_PROFILE_INFO' => $lang['Profile_info'],
          'L_PROFILE_INFO_NOTICE' => $lang['Profile_info_warn'],
          'L_EMAIL_ADDRESS' => $lang['Email_address'],
    AFTER, ADD
          'L_CONFIRM_CODE_IMPAIRED'   => sprintf($lang['Confirm_code_impaired'], '<a href="mailto:' . $board_config['board_email'] . '">', '</a>'),
          'L_CONFIRM_CODE'         => $lang['Confirm_code'],
          'L_CONFIRM_CODE_EXPLAIN'   => $lang['Confirm_code_explain'],
  • includes/usercp_sendpasswd.php
  1. FIND - Line 32
       $username = ( !empty($HTTP_POST_VARS['username']) ) ? trim(strip_tags($HTTP_POST_VARS['username'])) : '';
    REPLACE WITH
       $username = ( !empty($HTTP_POST_VARS['username']) ) ? phpbb_clean_username($HTTP_POST_VARS['username']) : '';
  • includes/usercp_viewprofile.php
  1. FIND - Line 172
    $page_title = $lang['Viewing_profile'];
    include($phpbb_root_path . 'includes/page_header.'.$phpEx);
    AFTER, ADD
    if (function_exists('get_html_translation_table'))
       $u_search_author = urlencode(strtr($profiledata['username'], array_flip(get_html_translation_table(HTML_ENTITIES))));
       $u_search_author = urlencode(str_replace(array('&amp;', ''', '&quot;', '&lt;', '&gt;'), array('&', "'", '"', '<', '>'), $profiledata['username']));
  2. FIND - Line 235
       'U_SEARCH_USER' => append_sid("search.$phpEx?search_author=" . urlencode($profiledata['username'])),
    REPLACE WITH
       'U_SEARCH_USER' => append_sid("search.$phpEx?search_author=" . $u_search_author),
  • login.php
  1. FIND - Line 57
          $username = isset($HTTP_POST_VARS['username']) ? trim(htmlspecialchars($HTTP_POST_VARS['username'])) : '';
    REPLACE WITH
          $username = isset($HTTP_POST_VARS['username']) ? phpbb_clean_username($HTTP_POST_VARS['username']) : '';
  • privmsg.php
  1. FIND - Line 1135
             $to_username = $HTTP_POST_VARS['username'];
    REPLACE WITH
             $to_username = phpbb_clean_username($HTTP_POST_VARS['username']);
  2. FIND - Line 1340
          $to_username = ( isset($HTTP_POST_VARS['username']) ) ? trim(strip_tags(stripslashes($HTTP_POST_VARS['username']))) : '';
    REPLACE WITH
          $to_username = (isset($HTTP_POST_VARS['username']) ) ? trim(htmlspecialchars(stripslashes($HTTP_POST_VARS['username']))) : '';
  3. FIND - Line 1711
          'USERNAME' => preg_replace($html_entities_match, $html_entities_replace, $to_username),
    REPLACE WITH
          'USERNAME' => $to_username,
  • profile.php
  1. FIND - Line 103
          include($phpbb_root_path . 'includes/usercp_register.'.$phpEx);
          exit;
    AFTER, ADD
       else if ( $mode == 'confirm' )
          if ( $userdata['session_logged_in'] )
             exit;
          include($phpbb_root_path . 'includes/usercp_confirm.'.$phpEx);
          exit;
  • search.php
  1. FIND - Line 63
       $search_author = htmlspecialchars($search_author);
    REPLACE WITH
       $search_author = phpbb_clean_username($search_author);
  • templates/subSilver/admin/board_config_body.tpl
  1. FIND - Line 38
          <td class="row2"><input type="radio" name="require_activation" value="{ACTIVATION_NONE}" {ACTIVATION_NONE_CHECKED} />{L_NONE}&nbsp; &nbsp;<input type="radio" name="require_activation" value="{ACTIVATION_USER}" {ACTIVATION_USER_CHECKED} />{L_USER}&nbsp; &nbsp;<input type="radio" name="require_activation" value="{ACTIVATION_ADMIN}" {ACTIVATION_ADMIN_CHECKED} />{L_ADMIN}</td>
    AFTER, ADD
          <td class="row1">{L_VISUAL_CONFIRM}<br /><span class="gensmall">{L_VISUAL_CONFIRM_EXPLAIN}</span></td>
          <td class="row2"><input type="radio" name="enable_confirm" value="1" {CONFIRM_ENABLE} />{L_YES}&nbsp; &nbsp;<input type="radio" name="enable_confirm" value="0" {CONFIRM_DISABLE} />{L_NO}</td>
  • viewtopic.php
  1. FIND - Line 486
       $words = explode(' ', trim(htmlspecialchars(urldecode($HTTP_GET_VARS['highlight']))));
    REPLACE WITH
       $words = explode(' ', trim(htmlspecialchars($HTTP_GET_VARS['highlight'])));
mgutt
easyUCP Visual Confirmation update für Boards > 2.0.10
Beitragvon AmigaLink » 21. Nov 2004 20:58
Danke für das Posten der Update-Anleitung, jetzt brauch ich das nicht mehr tun! :mrgreen:
Diejenigen die jetzt nicht wissen sollten worum es geht, finden hier die entsprechende Meldung und im Anhang die, für's Update, zusätzlich noch benötigten Files! 8)
Dieses Update schließt eine große Sicherheitslücke und ist deswegen sehr zu Empfehlen!!!
Nach der Installation dieses Updates muss für das easyUCP noch folgendes gemacht werden:
         $confirm_sql = '';
         do
      $code = '';
      unset($code);
         $confirm_sql = '';
         do
      $code = '';
      unset($code);
   if ( $ucp_mode == 'ucp_require' || $ucp_mode == '' )
      $template->assign_block_vars('switch_ucp_require', array());
      if ( $mode == 'editprofile' )
         $template->assign_block_vars('switch_ucp_require.switch_edit_profile', array());
      if ( ($mode == 'register') || ($board_config['allow_namechange']) )
         $template->assign_block_vars('switch_ucp_require.switch_namechange_allowed', array());
         $template->assign_block_vars('switch_ucp_require.switch_namechange_disallowed', array());
               $confirm_sql = '';
               do
            $code = '';
            unset($code);
            $template->assign_block_vars('switch_ucp_require.switch_confirm', array());
phpbb_update_files.zip
Update des phpBB 2.0.10 auf 2.0.11
(34.22 KiB) 1955-mal heruntergeladen
