Probleme bei der Installation
Beitragvon mgutt » 14. Okt 2004 22:24
Folgende Schritte kann ich nicht ausführen, da die Zeilen nicht auffindbar sind:
#-----[ OPEN ]--------------------------------------------------
includes/usercp_register.php
   if ( ($userdata['user_level'] == USER && $board_config['users_allow_absence'] == TRUE) || ($userdata['user_level'] != USER && $userdata['user_level'] != ANONYMOUS) )
      $template->assign_block_vars('allow_absence', array());
// <!-- BEGIN easyUCP -->
// <!-- END easyUCP -->
      $template->assign_block_vars('switch_validation', array() );
   if ( $mode == 'register' )
      $template->assign_block_vars('switch_ucp_require.switch_validation', array());
templates/subSilver/profile_add_body.tpl
#-----[ FIND ]--------------------------------------------------
<!-- END switch_validation -->
#-----[ AFTER, ADD ]--------------------------------------------------
<!-- END switch_ucp_require -->
<!-- BEGIN switch_ucp_cut -->
<table width="100%" border="0" cellpadding="3" cellspacing="1" class="forumline">
   <!-- END switch_ucp_cut -->
   <!-- BEGIN switch_ucp_info -->
<!-- End add - Birthday MOD -->
<!-- END switch_ucp_info -->
<!-- BEGIN switch_ucp_signature -->
<td class="row1"><span class="explaintitle">{SIG_DESC}:</span></td>
<td class="row2"><INPUT TYPE="button" VALUE="{SIG_BUTTON_DESC}" onclick="window.location.href='{SIG_EDIT_LINK}'"></td>
#-----[ REPLACE WITH ]--------------------------------------------------
<td class="row1"><span class="gen">{L_SIGNATURE}:</span><br /><span class="gensmall">{L_SIGNATURE_EXPLAIN}<br /><br />{HTML_STATUS}<br />{BBCODE_STATUS}<br />{SMILIES_STATUS}</span></td>
<td class="row2">
<textarea name="signature"style="width: 300px"  rows="6" cols="30" class="post">{SIGNATURE}</textarea>
</td>
<!-- END switch_ucp_signature -->
<!-- BEGIN switch_ucp_prefs -->
<td class="row1"><span class="gen">{L_HIDE_USER}:</span></td>
<td class="row2">
<input type="radio" name="hideonline" value="1" {HIDE_USER_YES} />
<span class="gen">{L_YES}</span>&nbsp;&nbsp;
<input type="radio" name="hideonline" value="0" {HIDE_USER_NO} />
<span class="gen">{L_NO}</span></td>
</table>
<!-- easyUCP -->
<td class="row1"><span class="explaintitle">{L_HIDE_PROFILE}:</span></td>
<td class="row2">
<table border="0" cellspacing="0" cellpadding="0">
<td><input type="radio" name="hideprofile" value="1" {HIDE_PROFILE_YES} />&nbsp;</td>
<td>{L_YES}&nbsp;&nbsp;</td>
<td><input type="radio" name="hideprofile" value="0" {HIDE_PROFILE_NO} />&nbsp;</td>
<td>{L_NO}</td>
</table>
<!-- easyUCP -->
<td class="row1"><span class="explaintitle">{L_DATE_FORMAT}:</span></td>
<td class="row2"><span class="gensmall">{DATE_FORMAT_SELECT}</span></td>
<!-- END switch_ucp_prefs -->
<!-- BEGIN switch_avatar_block -->
<td class="cat" colspan="2">&nbsp;</td>
</table>
<table border="0" cellpadding="0" cellspacing="0" class="tbl"><tr><td class="tbll"><img src="images/spacer.gif" alt="" width="8" height="4" /></td><td class="tblbot"><img src="images/spacer.gif" alt="" width="8" height="4" /></td><td class="tblr"><img src="images/spacer.gif" alt="" width="8" height="4" /></td></tr></table>
<br />
<!-- BEGIN switch_ucp_cut2 -->
<td class="cat" colspan="2" height="28">&nbsp;</td>
</table>
<br />
<!-- END switch_ucp_cut2 -->
<input type="reset" value="{L_RESET}" name="reset" class="button" />
{UCP_CANCEL}
templates/subSilver/admin/user_edit_body.tpl
<td class="row1">{L_HIDE_USER}</td>
<td class="row2">
{L_YES}&nbsp;&nbsp;
{L_NO}</td>
<!-- easyUCP -->
<td class="row1"><span class="gen">{L_HIDE_PROFILE}:</span></td>
<td class="row2">
<!-- easyUCP -->
mgutt
Beitragvon mgutt » 14. Okt 2004 22:32
ok, also der MOD "easyUCP 1.1.1 plus 1.5x.zip" ist nur für PHPBB2 Plus.
wer lesen kann ist klar im vorteil.
so dann nochmal von vorne :roll:
mgutt
Beitragvon mgutt » 14. Okt 2004 23:24
hab gerade ein minifehler gefunden:
   'body' => 'profile_view_body.tpl'
//   'body' => 'profile_view_body.tpl')
   'body' => 'easyucp_body.tpl')
bei "find" fehlt ne klammer, was aber eigentlich egal ist, wenn man das eh nicht mehr ändern will ;)
mgutt
Beitragvon mgutt » 14. Okt 2004 23:43
so fertig, alles wunderbar.
aber 20 min. installationszeit ist ja nicht gerade realistisch ;)
1 Std. vielleicht
ich habe fast 1 1/2 Std. gebraucht (trotz des 1. Fehlers, also ich wusste schon grob wo was hin muss)
mgutt
Beitragvon AmigaLink » 15. Okt 2004 12:19
Hallo mgut,
na da haste ja jetzt eine Safari hinter dir. ;)
Das ich bei meiner schätzung von 20 Minuten so weit unters Ziel geschossen habe, finde ich jetzt heftig. :shock:
Muss aber dabei sagen das diese angabe noch von der ersten Version ist, die noch ein wenig kleiner ausgefallen war. :twisted:
Beitragvon mgutt » 15. Okt 2004 12:36
Das kannste laut sagen. Aber ich bin irgendwie bei dem ZIP Paket wegen dem "Plus" davon ausgegangen, dass das Paket besser wäre :roll:
mgutt
Beitragvon AmigaLink » 15. Okt 2004 12:51
Naja wie du selber schon geschrieben hast, wer Lesen kann ist klar im Vorteil. :D
Übrigens hier findest du eine easyucp_body.tpl die in der zukünftigen Modversion enthalten sein wird. Sie ist kompatible zum Opera Browser. :)
Beitragvon LaraCroft » 22. Okt 2004 14:58
Hi AmigaLink,
Habe das Problem, dass wenn ich mein Profil aktualisiere. Es wieder resettet.
Irgendwie krieg ich den Einbau nicht richtig gebacken....
Bei Gelegenheit mal schauen ?!
Tester
tester
Danke
Lara[/url]
LaraCroft
Beitragvon AmigaLink » 22. Okt 2004 18:40
Das sieht mir si aus als hättest du folgenden Teil der installation, in der usercp_register, nicht oder fehlerhaft gemacht.
            SET " . $username_sql . $passwd_sql . "user_email = '" . str_replace("\'", "''", $email) ."', user_icq = '" . str_replace("\'", "''", $icq) . "', user_website = '" . str_replace("\'", "''", $website) . "', user_occ = '" . str_replace("\'", "''", $occupation) . "', user_from = '" . str_replace("\'", "''", $location) . "', user_from_flag = '$user_flag', user_interests = '" . str_replace("\'", "''", $interests) . "', user_absence_mode = $user_absence_mode, user_absence = $user_absence, user_absence_text = '" . str_replace("\'", "''", $user_absence_text) . "', user_birthday = '$birthday', user_next_birthday_greeting = '$next_birthday_greeting', user_viewemail = $viewemail, user_aim = '" . str_replace("\'", "''", str_replace(' ', '+', $aim)) . "', user_yim = '" . str_replace("\'", "''", $yim) . "', user_msnm = '" . str_replace("\'", "''", $msn) . "', user_attachsig = $attachsig, user_setbm = $setbm, user_allowsmile = $allowsmilies, user_allowhtml = $allowhtml, user_allowbbcode = $allowbbcode, user_allow_viewonline = $allowviewonline, user_notify = $notifyreply, user_notify_pm = $notifypm, user_popup_pm = $popup_pm, user_timezone = $user_timezone, user_dateformat = '" . str_replace("\'", "''", $user_dateformat) . "', user_lang = '" . str_replace("\'", "''", $user_lang) . "', user_style = $user_style, user_active = $user_active, user_actkey = '$user_actkey'" . $avatar_sql . ", user_gender = '$gender'
            WHERE user_id = $user_id";
         if ( isset($HTTP_GET_VARS['ucp_mode']) || isset($HTTP_POST_VARS['ucp_mode']) )
            $ucp_mode = ( isset($HTTP_GET_VARS['ucp_mode']) ) ? $HTTP_GET_VARS['ucp_mode'] : $HTTP_POST_VARS['ucp_mode'];
            $ucp_mode = htmlspecialchars($ucp_mode);
// Registration Info
         if ( $ucp_mode == 'ucp_require' || $ucp_mode == '' )
            SET " . $username_sql . $passwd_sql . "user_email = '" . str_replace("\'", "''", $email) ."', user_active = $user_active, user_actkey = '" . str_replace("\'", "''", $user_actkey) . "'
// Profile Info
         if ( $ucp_mode == 'ucp_info' || $ucp_mode == '' )
            SET user_icq = '" . str_replace("\'", "''", $icq) . "', user_website = '" . str_replace("\'", "''", $website) . "', user_occ = '" . str_replace("\'", "''", $occupation) . "', user_from = '" . str_replace("\'", "''", $location) . "', user_from_flag = '$user_flag', user_interests = '" . str_replace("\'", "''", $interests) . "', user_absence_mode = $user_absence_mode, user_absence = $user_absence, user_absence_text = '" . str_replace("\'", "''", $user_absence_text) . "', user_birthday = '$birthday', user_next_birthday_greeting = '$next_birthday_greeting', user_aim = '" . str_replace("\'", "''", str_replace(' ', '+', $aim)) . "', user_yim = '" . str_replace("\'", "''", $yim) . "', user_msnm = '" . str_replace("\'", "''", $msn) . "', user_gender = '$gender'
// Preferences
            SET user_viewemail = $viewemail, user_attachsig = $attachsig, user_allowsmile = $allowsmilies, user_allowhtml = $allowhtml, user_allowbbcode = $allowbbcode, user_allow_viewonline = $allowviewonline, user_allow_viewprofile = $allowviewprofile, user_notify = $notifyreply, user_notify_pm = $notifypm, user_popup_pm = $popup_pm, user_timezone = $user_timezone, user_dateformat = '" . str_replace("\'", "''", $user_dateformat) . "', user_lang = '" . str_replace("\'", "''", $user_lang) . "', user_style = $user_style
// Avatar
         if ( $ucp_mode == 'ucp_avatar' && $avatar_sql != '' || $ucp_mode == '' && $avatar_sql != '' )
            SET " . substr($avatar_sql,2) . "
// Signature
         if ( $ucp_mode == 'ucp_signature' || $ucp_mode == '' )
            SET user_sig_bbcode_uid = '$signature_bbcode_uid', user_sig = '" . str_replace("\'", "''", $signature) . "'
Beitragvon LaraCroft » 22. Okt 2004 18:50
Also überprüf ich das mal...was ist mit den mods die noch drinnstehen ? die werden ja dann gelöscht oder wo trag ich die wieder ein.
Ich peil das nit so, hab bei keinem Mod so ein qualmenden Kopf gehabt...hab gestern 10 mal angefangen und zu guter letzt hab ich auchnoch versehntlich meine Backupdateien gelöscht....dann war ich erstmal fertig mit dem Teil....und bin ins Bett.
LaraCroft
Mitglieder in diesem Forum: Baidu [Spider] und 2 Gäste
