MODs die man ohne zusätzliche Anleitung einbauen kann!
Beitragvon AmigaLink » 1. Sep 2004 00:20
Bei folgenden Mods muss bei Installation ins easyUCP nichts beachten werden !!! 8)
(Ausser das eventuelle eintragungen in die usercp_viewprofile.tpl in die easyucp_body.tpl gesetzt werden müssen!)
Mods von mir werden hier nicht aufgeführt, da diese (falls nötig) ein Addon im Packet haben. :)
## Mod Title: Showing other Signatures on/off
## Mod Version: 1.0
## Author: EGO2000
## Description: This mod allow User to switch on/off showing the signatures of all other Members
## MOD Title: Extended Ranks System [2.0.8]
## MOD Author: mosymuis < mods@mosymuis.nl > (Rens van Dongen) http://mods.mosymuis.nl
## MOD Description: This mod allows you to set up diffrent rank sets,
## wich you can use to attach different post count ranks
## to individual users, users who use a certain template
## or users who are either male or female. You can choose
## to allow your members to choose their own rank set,
## with the option to hide certain rank sets from them.
## You can also apply special ranks to banned users, users
## who celebrate their birthday, users with an admin or
## moderator status or people who are in one of the usergroups.
## MOD Version: 1.0.1
## MOD Title: Advanced time management
## MOD Author: -=ET=- < space_et@tiscali.fr > (n/a) http://www.golfexpert.net/phpbb
## MOD Description: This MOD will allow the board administrators
## and each user to manage the time displayed
## on the board.
## They will be able to:
## - set the DST time lag of their state/country
## - enable/disable manually the DST
## - just synchronize DST switches with the server ones
## - fully use the server local time
## - fully use the server UTC time & the user's computer settings
## - fully use the user's computer local time
## MOD Version: 2.0.0
Zuletzt geändert von AmigaLink am 5. Aug 2005 16:57, insgesamt 6-mal geändert.
Beitragvon AmigaLink » 13. Sep 2004 22:10
## Mod Title: Vault
## Mod Author: Dr DLP < > ( Malicious Rabbit ) http://www.lapin-malin.com
## Mod Description: A vault system for your forum
## Mod Version: 1.0.0
## Mod Title: Medal System
## Mod Version: 2.2.2
## Mod Author: Mac (Y.C. LIN) < ycl6 ->AT<- users.sourceforge ->DOT<- net >
## http://macphpbbmod.sourceforge.net/
## Mod Description: This Mod is a complete Medal system for your phpBB forum.
## Mod Title: Badge in Profile Hack
## Mod Author: TheGatesofBill
## Mod Description: This Hack will change the layout of the avatar on the view profile
## page to look closer to the way it does on the view topic page.
Beitragvon AmigaLink » 8. Mai 2005 00:39
## MOD Title: Translate posts
## MOD Author: Niels < ncr@db9.dk > (Niels Chr. Rød) http://mods.db9.dk
## MOD Description: This mod will give both guests and registered
## users, the ability to translate the posts
## into there own language selected in there
## profile (guest will have board language).
## MOD Version: 0.5.6 RC3c
Mitglieder in diesem Forum: Bing [Bot] und 7 Gäste
