easyUCP vs Stop Spambot Registration 1.0.2a
Beitragvon Coroner » 6. Sep 2007 22:40
Hello again folks. I found a problem that for the life of me I can't resolve on my own. I had a similar issue with another mod and by following the instructions from the "install notes for other mods" I was able to figure it out but this time I'm stumped and need your help please!
I have had the above mentioned mod install for a long time. I continue to get the email alerts so I know that part still works but there's a part that is supposed to show a brite red line just above the "Profile Information" line in the registration field that warns people not to enter anything in the fields below that line or the registration will fail. http://cscoroner.com/phpBB2/index.php
It's not showing up anymore and I don't know what code changes are needed to make it appear again.
I'm attaching the usercp_register.php, profile add body.tpl and Stop Spambot Registration 1.0.2a for your review.
Please let me know!
As always, thank you so much for all your efforts and support.
Stop_Spambot_Registration-1.0.2a.zip
(3.13 KiB) 2914-mal heruntergeladen
profile_add_body.zip
(2.7 KiB) 2855-mal heruntergeladen
usercp_register.zip
(13.89 KiB) 2884-mal heruntergeladen
Coroner
Spender
Beitragvon AmigaLink » 7. Sep 2007 15:51
The solution would have to be:
includes/usercp_register.php
      if ( ($mode == 'register') || ($board_config['allow_namechange']) )
         $template->assign_block_vars('switch_ucp_require.switch_namechange_allowed', array());
//----BEGIN Stop Spambot Registration MOD
      if ( $mode == 'register' )
         $template->assign_block_vars('switch_ucp_info.switch_register', array());
         $template->assign_vars(array(
            'SPAMBOT_MESSAGE' => $lang['Spambot_message'],
            'SPAMBOT_MESSAGE_EXPLAIN' => $lang['Spambot_message_explain'])
//----END Stop Spambot Registration MOD
Beitragvon Coroner » 10. Sep 2007 03:05
Worked like a charm!
Once again, thank you so much for a great mod and all your efforts and support.
Coroner
Spender
Beitragvon AmigaLink » 10. Sep 2007 12:03
Nice to hear that. :)
