Categories Hierarchy Mod
Beitragvon mgutt » 9. Feb 2005 01:26
#-----[ OPEN ]------------------------------------------------
includes/usercp_register.php
#-----[ FIND ]------------------------------------------------
<?php
//-- mod : categories hierarchy ------------------------------------------------
# this is a partial search : the full lines are longer
            message_die(GENERAL_ERROR, 'Could not update users table',
//-- add
         // if name changed, update some data
         if ( !empty($username_sql) )
            $fields = array(
               'forum_last_username' => stripslashes($username),
            $db->sql_statement($fields);
            // update forums last poster
            $sql = 'UPDATE ' . FORUMS_TABLE . '
                     SET ' . $db->sql_update . '
                     WHERE forum_last_poster = ' . intval($user_id);
            $db->sql_query($sql, false, __LINE__, __FILE__);
            // update last user
            if ( ($user_id == $config->data['stat_last_user']) || empty($config->data['stat_last_username']) )
               $config->set('stat_last_user', $user_id);
               $config->set('stat_last_username', stripslashes($username));
            // recache moderators
            include_once($config->url('includes/class_forums'));
            $moderators = new moderators();
            $moderators->set_users_status();
            $moderators->read(true);
//-- fin mod : categories hierarchy --------------------------------------------
Was ist der richtige Code dann für den UCP Mod an der Stelle?
mgutt
Beitragvon AmigaLink » 9. Feb 2005 12:43
Der CH und der easyUCP vertragen sich ohne jeglich anpassung!
Tu beim einbau des easyUCP einfach so, als wäre der zusätzliche code vom CH garnicht vorhanden. ;)
Beitragvon mgutt » 10. Feb 2005 01:20
ich hätte jetzt so getan. also ganz weglassen? na gut :wink:
// Registration Info
         if ( $ucp_mode == 'ucp_require' || $ucp_mode == '' )
            SET " . $username_sql . $passwd_sql . "user_email = '" . str_replace("\'", "''", $email) ."', user_active = $user_active, user_actkey = '" . str_replace("\'", "''", $user_actkey) . "'
            WHERE user_id = $user_id";
//-- add
            $fields = array(
            // update last user
mgutt
Beitragvon AmigaLink » 10. Feb 2005 13:16
Was ist das überhaupt für ein Codeblock?
Mir fällt jetzt erst auf das ich diesen Code nicht kenne. :roll:
Ist der vom CH 2.1???
Bau mal so ein wie du es gepostet hast! Das sieht gut aus. :D
Beitragvon mgutt » 10. Feb 2005 16:43
jo das ist 2.1.0
mein Forum quillt über vor lauter neuen Sachen.. oh mann alles wieder rauslösche harhar
mgutt
Beitragvon AmigaLink » 10. Feb 2005 20:14
Soviele neue sachen im 2.1? :shock:
Naja, ich werde diese version erst einbauen wenn sie final ist und selbst dann werd ich sie mir vorher genau ansehen.
Mitglieder in diesem Forum: Baidu [Spider] und 2 Gäste
