News Archive
News Archive
Beitragvon M3ndax » 24. Jan 2008 18:25
M3ndax
Beitragvon AmigaLink » 4. Feb 2008 23:58
"At a glance 4" by Blulegend
Ported to a IM-Portal block and combined with the Multipage function from the IM-Portal.
My ported version of "At a Glance" can be find at oxpus.de
Beitragvon M3ndax » 9. Feb 2008 13:39
can you put heir your glance.php file?
M3ndax
Beitragvon AmigaLink » 20. Feb 2008 09:59
No sorry.
The file I used here does not work on other boards. Because AmigaLink.de has many codechanges (own functions and classes).
The file you can find at oxpus.de will be for "normaly" boards. I have createt it for a User long time ago and I doesn't have the file at my archive. :?
Zugefügt nach 6 Minute(n):
Here you can find the file: http://www.oxpus.de/viewtopic.php?p=48841#48841 :)
