how to deal with this?
Beitragvon wicher » 10. Apr 2006 19:47
Hello, i came across a little problem with lexicon.
For example i create folowing 3 lexicon words:
"coin", "golden", "golden coin".
Now, when i make a post in phpbb only the word "coin" gets linked to the lexicon.
So the word "golden coin" will never get linked.
Golden does get linked but only when it is as a stand alone word in a post.
Maybe its something to think over for future lexicon versions?
wicher
Beitragvon AmigaLink » 10. Apr 2006 21:53
Yes, I know this problem. And I try to solve it in one of the next versions.
Place "golden coin" as "golden_coin" in the lexicon to fix the problem that "golden coin" will be linked to "golden" and "coin".
Beitragvon wicher » 15. Apr 2006 19:18
Will be hard to solv ei think?
I hope you find a way, i'll be waiting. :wink:
wicher
