Ckecking if word are allready in lexicon
Beitragvon wicher » 19. Mär 2006 00:14
in admin_lexicon_edit.php i changed a bit of code so it now checks if a new word allready exists in the lexicon:
i did this, maybe there is better code, but it works for me:
#FIND:
   // confirms new keyword
   case 'new_keyword_confirms':
      $admin_lexicon_action_url = append_sid("admin_lexicon_edit.$phpEx");
      ($categorie_id == 0) ? $categorie_id = 1 : '';
      $bbcode_uid = make_bbcode_uid();
      $explanation = prepare_message(trim($explanation), $html_on, $bbcode_on, $smile_on, $bbcode_uid);
      $mode = '';
      // insert new keyword in database
      $sql="INSERT INTO " . LEXICON_ENTRY_TABLE . " ( id, keyword, explanation, bbcode_uid, cat) VALUES ('', '$keyword', '$explanation', '$bbcode_uid', $categorie_id)";
         message_die(GENERAL_ERROR, 'Error update lexicon entry', '', __LINE__, __FILE__, $sql);
      // Grab lexicon categories
      $sql = "SELECT cat_id, cat_titel FROM " . LEXICON_CAT_TABLE;
      if(!$result = $db->sql_query($sql))
         message_die(GENERAL_ERROR, 'Could not get categories list', '', __LINE__, __FILE__, $sql);
      while($row = $db->sql_fetchrow($result))
         $lexicon_categories[$row['cat_id']] = $row['cat_titel'];
      $db->sql_freeresult($result);
      $message = '<br />' . sprintf($lang['Keyword_caused'], $keyword, $lexicon_categories[$categorie_id]);
      $message .= '<br /><br /><meta http-equiv="refresh" content="1;url=' . $admin_lexicon_action_url . '">';
      message_die(GENERAL_MESSAGE, $message);
      break;
# REPLACE WITH:
      $exist = 0;
      $keyword = strtolower($keyword);
      $sql = "SELECT keyword FROM " . LEXICON_ENTRY_TABLE;
         message_die(GENERAL_ERROR, 'Kon encyclopediewoord niet checken', '', __LINE__, __FILE__, $sql);
         $existkeyword = $row['keyword'];
         if ($existkeyword == $keyword){$exist = 1;}
      if ($exist)
      $message = '<br /><br />This word allready exists in the Lexicon<br />Click <a href="#" onClick="history.go(-1)">Back</a> to give your word another name or to copy your text and see if you can improve the existing word with it.<br><br>Click <a href="lexicon.php">here</a> to go to the Lexicon.';
      break;
      $admin_lexicon_action_url = append_sid("lexicon_edit.$phpEx");
      $poster = $userdata['username'];
      $mode = '';
      $sql="INSERT INTO " . LEXICON_ENTRY_TABLE . " ( id, keyword, explanation, bbcode_uid, cat, poster) VALUES ('', '$keyword', '$explanation', '$bbcode_uid', $categorie_id, '$poster')";
      break;
wicher
Beitragvon AmigaLink » 19. Mär 2006 00:47
Thank you, wicher! 8)
I will insert this code, or a something similar, in one of the next versions.
Beitragvon wicher » 19. Mär 2006 01:31
:wink:
wicher
Beitragvon DieterB » 19. Mär 2006 08:04
Nice,
but i get this Error-Message:
SQL Error : 1054 Unknown column 'poster' in 'field list'
INSERT INTO phpbb_lexicon ( id, keyword, explanation, bbcode_uid, cat, poster) VALUES ('', '', '', '', 2, '')
Line : 142
File : admin_lexicon_edit.php
Values are my UserName, my Paasword and the Keyword and text
Gruß
DieterB
(Auch der längste Weg beginnt mit dem ersten Schritt)
DieterB
Beitragvon AmigaLink » 19. Mär 2006 08:51
Wicher hat offenbar ein zuzätzliches Tabellenfeld eingefügt.
Ersetze
gegen
Beitragvon DieterB » 19. Mär 2006 09:46
Der nächste Fehler der mir aufgefallen ist,
habe ich ein Stichwort, z.B. "Absteifen" im Lexikon, und will ich dieses hinzufügen, wird es als "absteifen" mit übernommen.
D.h.: der erste Buchstabe wird in einen Kleinbuchstaben umgewandelt, und erst beim 2. mal, kommt die Fehlermeldung.
Und wenn man es dann editiert hat, klappt es auch.
Lösung:
$exist = 0;
//$keyword = strtolower($keyword); Diese Zeile wurde auskommentiert
Zugefügt nach 15 Minute(n):
Und hier einmal der (von mir) überarbeitete Code.
Folgende Änderungen habe ich vorgenommen:
1. Die Zeile
wurde von mir entfernt, sie wandelte den ersten Buchstaben in einen Kleinbuchstaben um, so dass die doppelte Eingabe nicht abgefangen wurde.
2. Die URL zum Lexikon wurde von mir dahingehend angepasst,
dass sich das Lexikon (Klick auf 2. Link) in einem neuen Fenster öffnet.
In Wicher's Version kam eine Fehlermeldung, wegen fehlender oder unkorrekter Pfadzuweisung
<br><br>Klicke <a href="../lexicon.php" target="Blank">hier</a> um zum Lexikon zu gelangen
3. die Fehlermeldung wurde von mir in's deutsche übersetzt.
Hier noch einmal der komplette Code.
Ersetzt einfach Wicher's Code durch meinen.
Diese version ist für deutsche User des Lexikons.
      $exist = 0;
      if ($exist)
      $message = '<br /><br />Dieses Stichwort ist bereits in der Datenbank vorhanden. Klicke <a href="#" onClick="history.go(-1)">Neu</a> um dem Wort eine neue Bezeichnung zu geben.<br>Oder kopiere den Text, und schaue ob du ihn verbessern oder erweitern kannst.<br><br>Klicke <a href="../lexicon.php" target="Blank">hier</a> um zum Lexikon zu gelangen.';
      break;
      $mode = '';
      break;
Gruß
DieterB
DieterB
Beitragvon wicher » 19. Mär 2006 12:00
Yes, i added a table field.
Sorry about not thinking about that.
And i put all lexicon words lowercase in the database because the caseunsensible fix does not work for me.
So i make sure all the words are put in in lowercase.
Thanks for changing above to correct code.
wicher
Beitragvon DieterB » 28. Apr 2006 17:15
today, i've found 1 mistake more.
lokk at here
when i'am changing the file against the original, it's ok
but the code checked up for double-words anymore
Zugefügt nach 23 Minute(n):
i've found!!!
You must change in the line
lexicon_edit against admin_lexicon_edit
Gruß
DieterB
DieterB
Beitragvon wicher » 28. Apr 2006 21:08
I am sorry about that, i did not think about that when i copied it from my own files.
Fact is that i expanded my lexicon so that my users all can add words to it.
Therefor i duplicated some files from the admin to the root of my phpbb and renamed them to the same names without the "admin_" in front.
After that i did some further codechanges to them and now i can give certain users or all access to edit the lexicon.
I have it now in a way like you see at http://nl.wikipedia.org.
Its like an open encyclopedia where everybody can add there info into and edit the info that others made.
Zugefügt nach 19 Minute(n):
Here is better code, same usage as first post but now with corrected codes like the errors discussed above.
Also this code does not put all words in the lexicon in lowercase but does check all words in the lexicon wether they have uppercase letters or not.
      $exist = 0;
      $keywordcheck = strtolower($keyword);
         message_die(GENERAL_ERROR, 'Could not check Lexiconword', '', __LINE__, __FILE__, $sql);
         $existkeyword = strtolower($row['keyword']);
         if ($existkeyword == $keywordcheck){$exist = 1;}
      if ($exist)
      break;
      $mode = '';
      break;
wicher
