Error after search / search not working ?
Beitragvon usadutch » 10. Jun 2005 03:33
Hi To start with I like this MOD, it was just what I needed.
However I have a error when I search a word that is not in the database;
Warning: sprintf(): Too few arguments in .../forum/lexicon.php on line 251
Searching on a word that actualy is in the database gives no result. It looks like the search is not working at all.
Please see http://usadutch.com/forum and click in the top bar VISA Lexicon.
thanks
You can answer me in German, I can understand that perfectly.
Nich ist sicher und eben das is auch nicht sicher.
I write in English but you can answer me in German
Ich kan das lezen und verstehen.
Forum http://usadutch.com/forum
usadutch
Beitragvon AmigaLink » 10. Jun 2005 11:24
There must be a mistake in your lang_main.php.
Please check the $lang['Lexicon_search_error'] entry in that file.
Zugefügt nach 13 Minute(n):
I found the problem. I have an error made by translate the mod. :roll:
Please take this line in your lang_main.php in place of the existing one.
$lang['Lexicon_search_error'] = 'Unfortunately there is no entry like <b>%s</b> in our '.$lang['Lexicon'].'.<br />Ask nevertheless in the forum please to whether someone can help you!';
Beitragvon usadutch » 10. Jun 2005 14:03
Thank you this did the trick, this is solved now. :)
usadutch
Beitragvon AmigaLink » 10. Jun 2005 14:33
Fine :)
Mitglieder in diesem Forum: Majestic-12 [Bot] und 2 Gäste
