Problems with Online Indicator
Online-Statusanzeige im Profil, der Viewtopic und in der Mitgliederliste
Beitragvon feldon » 10. Jan 2005 17:21
Hi
I install your mod to my phpBB and everything seams to be OK.
But problem is when I vieuw Memberslist It stay saing that everybody is OFLINE :cry:
While i open topic of viewprofile everything is showing right.
With memberslist I see as ADMIN that all users are HIDE...
I was trying to install it a few times to see If I didn't make some
mistakes but looks like all was corectly.
Any idea ?
My Portal & Forum
feldon
Beitragvon AmigaLink » 10. Jan 2005 20:08
Hmm - strangely?!
Please attach me the memberlist.php and i will take a look at it.
Beitragvon feldon » 10. Jan 2005 20:23
Hi
Sure.
Thank YOU :!:
Only problem is where do I have to send that ?
I'll post that here you can always delete it afterwards :wink:
<?php
*                              memberlist.php
*   begin                : Friday, May 11, 2001
*   copyright            : (C) 2001 The phpBB Group
*   email                : support@phpbb.com
*   $Id: memberlist.php,v 1.36.2.9 2004/03/01 15:56:52 psotfx Exp $
*   This program is free software; you can redistribute it and/or modify
*   it under the terms of the GNU General Public License as published by
*   the Free Software Foundation; either version 2 of the License, or
*   (at your option) any later version.
define('IN_PHPBB', true);
$phpbb_root_path = './';
include($phpbb_root_path . 'extension.inc');
include($phpbb_root_path . 'common.'.$phpEx);
// Start session management
$userdata = session_pagestart($user_ip, PAGE_VIEWMEMBERS);
init_userprefs($userdata);
if ( !$userdata['session_logged_in'] )
   redirect("login.".$phpEx);
   exit;
// End session management
$start = ( isset($HTTP_GET_VARS['start']) ) ? intval($HTTP_GET_VARS['start']) : 0;
if ( isset($HTTP_GET_VARS['mode']) || isset($HTTP_POST_VARS['mode']) )
   $mode = ( isset($HTTP_POST_VARS['mode']) ) ? htmlspecialchars($HTTP_POST_VARS['mode']) : htmlspecialchars($HTTP_GET_VARS['mode']);
   $mode = 'joined';
if(isset($HTTP_POST_VARS['order']))
   $sort_order = ($HTTP_POST_VARS['order'] == 'ASC') ? 'ASC' : 'DESC';
else if(isset($HTTP_GET_VARS['order']))
   $sort_order = ($HTTP_GET_VARS['order'] == 'ASC') ? 'ASC' : 'DESC';
   $sort_order = 'ASC';
// Memberlist sorting
$mode_types_text = array($lang['Sort_Joined'], $lang['Sort_Username'], $lang['Sort_Location'], $lang['Sort_Posts'], $lang['Sort_Email'],  $lang['Sort_Website'], $lang['Sort_Top_Ten']);
$mode_types = array('joindate', 'username', 'location', 'posts', 'email', 'website', 'topten');
$select_sort_mode = '<select name="mode">';
for($i = 0; $i < count($mode_types_text); $i++)
   $selected = ( $mode == $mode_types[$i] ) ? ' selected="selected"' : '';
   $select_sort_mode .= '<option value="' . $mode_types[$i] . '"' . $selected . '>' . $mode_types_text[$i] . '</option>';
$select_sort_mode .= '</select>';
$select_sort_order = '<select name="order">';
if($sort_order == 'ASC')
   $select_sort_order .= '<option value="ASC" selected="selected">' . $lang['Sort_Ascending'] . '</option><option value="DESC">' . $lang['Sort_Descending'] . '</option>';
   $select_sort_order .= '<option value="ASC">' . $lang['Sort_Ascending'] . '</option><option value="DESC" selected="selected">' . $lang['Sort_Descending'] . '</option>';
$select_sort_order .= '</select>';
// Generate page
$page_title = $lang['Memberlist'];
include($phpbb_root_path . 'includes/page_header.'.$phpEx);
   'body' => 'memberlist_body.tpl')
make_jumpbox('viewforum.'.$phpEx);
$template->assign_vars(array(
   'L_SELECT_SORT_METHOD' => $lang['Select_sort_method'],
   'L_EMAIL' => $lang['Email'],
   'L_WEBSITE' => $lang['Website'],
   'L_FROM' => $lang['Location'],
   'L_ORDER' => $lang['Order'],
   'L_SORT' => $lang['Sort'],
   'L_SUBMIT' => $lang['Sort'],
   'L_AIM' => $lang['AIM'],
   'L_YIM' => $lang['YIM'],
   'L_MSNM' => $lang['MSNM'],
   'L_ICQ' => $lang['ICQ'],
// Start add - Rank in member list MOD
'L_USER_RANK' => $lang['Poster_rank'],
// End add - Rank in member list MOD
   'L_JOINED' => $lang['Joined'],
   'L_POSTS' => $lang['Posts'],
   'L_PM' => $lang['Private_Message'],
   'S_MODE_SELECT' => $select_sort_mode,
   'S_ORDER_SELECT' => $select_sort_order,
   'S_MODE_ACTION' => append_sid("memberlist.$phpEx"))
switch( $mode )
   case 'joined':
      $order_by = "user_regdate $sort_order LIMIT $start, " . $board_config['topics_per_page'];
      break;
   case 'username':
      $order_by = "username $sort_order LIMIT $start, " . $board_config['topics_per_page'];
      break;
   case 'location':
      $order_by = "user_from $sort_order LIMIT $start, " . $board_config['topics_per_page'];
      break;
   case 'posts':
      $order_by = "user_posts $sort_order LIMIT $start, " . $board_config['topics_per_page'];
      break;
   case 'email':
      $order_by = "user_email $sort_order LIMIT $start, " . $board_config['topics_per_page'];
      break;
   case 'website':
      $order_by = "user_website $sort_order LIMIT $start, " . $board_config['topics_per_page'];
      break;
   case 'topten':
      $order_by = "user_posts $sort_order LIMIT 10";
      break;
   default:
      break;
$sql = "SELECT *
   FROM " . RANKS_TABLE . "
   ORDER BY rank_special, rank_min";
   message_die(GENERAL_ERROR, "Could not obtain ranks information.", '', __LINE__, __FILE__, $sql);
$ranksrow = array();
while ( $row = $db->sql_fetchrow($result) )
   $ranksrow[] = $row;
$db->sql_freeresult($result);
$sql = "SELECT username, user_id, user_viewemail, user_posts, user_regdate, user_from, user_website, user_email, user_icq, user_aim, user_yim, user_msnm, user_avatar, user_avatar_type, user_allowavatar, user_rank
   FROM " . USERS_TABLE . "
   WHERE user_id <> " . ANONYMOUS . "
   ORDER BY $order_by";
if( !($result = $db->sql_query($sql)) )
   message_die(GENERAL_ERROR, 'Could not query users', '', __LINE__, __FILE__, $sql);
if ( $row = $db->sql_fetchrow($result) )
   $i = 0;
   do
      $username = $row['username'];
      $user_id = $row['user_id'];
      $from = ( !empty($row['user_from']) ) ? $row['user_from'] : '&nbsp;';
      $joined = create_date($lang['DATE_FORMAT'], $row['user_regdate'], $board_config['board_timezone']);
      $posts = ( $row['user_posts'] ) ? $row['user_posts'] : 0;
// Generate ranks, set them to empty string initially
$user_rank = '';
$rank_image = '';
if ( $row['user_rank'] )
   for($j = 0; $j < count($ranksrow); $j++)
      if ( $row['user_rank'] == $ranksrow[$j]['rank_id'] && $ranksrow[$j]['rank_special'] )
         $user_rank = $ranksrow[$j]['rank_title'];
         $rank_image = ( $ranksrow[$j]['rank_image'] ) ? '<img src="' . $ranksrow[$j]['rank_image'] . '" alt="' . $poster_rank . '" title="' . $poster_rank . '" border="0" /><br />' : '';
      if ( $row['user_posts'] >= $ranksrow[$j]['rank_min'] && !$ranksrow[$j]['rank_special'] )
      $poster_avatar = '';
      if ( $row['user_avatar_type'] && $user_id != ANONYMOUS && $row['user_allowavatar'] )
         switch( $row['user_avatar_type'] )
            case USER_AVATAR_UPLOAD:
               $poster_avatar = ( $board_config['allow_avatar_upload'] ) ? '<img src="' . $board_config['avatar_path'] . '/' . $row['user_avatar'] . '" alt="" border="0" />' : '';
               break;
            case USER_AVATAR_REMOTE:
               $poster_avatar = ( $board_config['allow_avatar_remote'] ) ? '<img src="' . $row['user_avatar'] . '" alt="" border="0" />' : '';
               break;
            case USER_AVATAR_GALLERY:
               $poster_avatar = ( $board_config['allow_avatar_local'] ) ? '<img src="' . $board_config['avatar_gallery_path'] . '/' . $row['user_avatar'] . '" alt="" border="0" />' : '';
               break;
// <!-- BEGIN Another Online/Offline indicator -->
      if ( !$row['user_allow_viewonline'] && $userdata['user_level'] == ADMIN || $row['user_allow_viewonline'] )
         $current_time = time();
         $expiry_time = $current_time - 300;
         if ( $row['user_session_time'] >= $expiry_time )
            $user_onlinestatus = '<img src="' . $images['Online'] . '" alt="' . $lang['Online'] . '" title="' . $lang['Online'] . '" border="0" />';
            if ( !$row['user_allow_viewonline'] && $userdata['user_level'] == ADMIN )
               $user_onlinestatus = '<img src="' . $images['Hidden_Admin'] . '" alt="' . $lang['Hidden'] . '" title="' . $lang['Hidden'] . '" border="0" />';
            $user_onlinestatus = '<img src="' . $images['Offline'] . '" alt="' . $lang['Offline'] . '" title="' . $lang['Offline'] . '" border="0" />';
               $user_onlinestatus = '<img src="' . $images['Offline'] . '" alt="' . $lang['Hidden'] . '" title="' . $lang['Hidden'] . '" border="0" />';
// <!-- END Another Online/Offline indicator -->
      if ( !empty($row['user_viewemail']) || $userdata['user_level'] == ADMIN )
         $email_uri = ( $board_config['board_email_form'] ) ? append_sid("profile.$phpEx?mode=email&amp;" . POST_USERS_URL .'=' . $user_id) : 'mailto:' . $row['user_email'];
         $email_img = '<a href="' . $email_uri . '"><img src="' . $images['icon_email'] . '" alt="' . $lang['Send_email'] . '" title="' . $lang['Send_email'] . '" border="0" /></a>';
         $email = '<a href="' . $email_uri . '">' . $lang['Send_email'] . '</a>';
         $email_img = '&nbsp;';
         $email = '&nbsp;';
      $temp_url = append_sid("profile.$phpEx?mode=viewprofile&amp;" . POST_USERS_URL . "=$user_id");
      $profile_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_profile'] . '" alt="' . $lang['Read_profile'] . '" title="' . $lang['Read_profile'] . '" border="0" /></a>';
      $profile = '<a href="' . $temp_url . '">' . $lang['Read_profile'] . '</a>';
      $temp_url = append_sid("privmsg.$phpEx?mode=post&amp;" . POST_USERS_URL . "=$user_id");
      $pm_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_pm'] . '" alt="' . $lang['Send_private_message'] . '" title="' . $lang['Send_private_message'] . '" border="0" /></a>';
      $pm = '<a href="' . $temp_url . '">' . $lang['Send_private_message'] . '</a>';
      $www_img = ( $row['user_website'] ) ? '<a href="' . $row['user_website'] . '" target="_userwww"><img src="' . $images['icon_www'] . '" alt="' . $lang['Visit_website'] . '" title="' . $lang['Visit_website'] . '" border="0" /></a>' : '';
      $www = ( $row['user_website'] ) ? '<a href="' . $row['user_website'] . '" target="_userwww">' . $lang['Visit_website'] . '</a>' : '';
      if ( !empty($row['user_icq']) )
         $icq_status_img = '<a href="http://wwp.icq.com/' . $row['user_icq'] . '#pager"><img src="http://web.icq.com/whitepages/online?icq=' . $row['user_icq'] . '&img=5" width="18" height="18" border="0" /></a>';
         $icq_img = '<a href="http://wwp.icq.com/scripts/search.dll?to=' . $row['user_icq'] . '"><img src="' . $images['icon_icq'] . '" alt="' . $lang['ICQ'] . '" title="' . $lang['ICQ'] . '" border="0" /></a>';
         $icq =  '<a href="http://wwp.icq.com/scripts/search.dll?to=' . $row['user_icq'] . '">' . $lang['ICQ'] . '</a>';
         $icq_status_img = '';
         $icq_img = '';
         $icq = '';
      $aim_img = ( $row['user_aim'] ) ? '<a href="aim:goim?screenname=' . $row['user_aim'] . '&amp;message=Hello+Are+you+there?"><img src="' . $images['icon_aim'] . '" alt="' . $lang['AIM'] . '" title="' . $lang['AIM'] . '" border="0" /></a>' : '';
      $aim = ( $row['user_aim'] ) ? '<a href="aim:goim?screenname=' . $row['user_aim'] . '&amp;message=Hello+Are+you+there?">' . $lang['AIM'] . '</a>' : '';
      $msn_img = ( $row['user_msnm'] ) ? '<a href="' . $temp_url . '"><img src="' . $images['icon_msnm'] . '" alt="' . $lang['MSNM'] . '" title="' . $lang['MSNM'] . '" border="0" /></a>' : '';
      $msn = ( $row['user_msnm'] ) ? '<a href="' . $temp_url . '">' . $lang['MSNM'] . '</a>' : '';
      $yim_img = ( $row['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $row['user_yim'] . '&amp;.src=pg"><img src="' . $images['icon_yim'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
      $yim = ( $row['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $row['user_yim'] . '&amp;.src=pg">' . $lang['YIM'] . '</a>' : '';
      $temp_url = append_sid("search.$phpEx?search_author=" . urlencode($username) . "&amp;showresults=posts");
      $search_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_search'] . '" alt="' . $lang['Search_user_posts'] . '" title="' . $lang['Search_user_posts'] . '" border="0" /></a>';
      $search = '<a href="' . $temp_url . '">' . $lang['Search_user_posts'] . '</a>';
      $row_color = ( !($i % 2) ) ? $theme['td_color1'] : $theme['td_color2'];
      $row_class = ( !($i % 2) ) ? $theme['td_class1'] : $theme['td_class2'];
      $template->assign_block_vars('memberrow', array(
         'ROW_NUMBER' => $i + ( $HTTP_GET_VARS['start'] + 1 ),
         'ROW_COLOR' => '#' . $row_color,
         'ROW_CLASS' => $row_class,
         'USERNAME' => $username,
         'ONLINESTATUS' => $user_onlinestatus,
         'FROM' => $from,
         'JOINED' => $joined,
'USER_RANK' => $user_rank,
'USER_RANK_IMG' => $rank_image,
         'POSTS' => $posts,
         'AVATAR_IMG' => $poster_avatar,
         'PROFILE_IMG' => $profile_img,
         'PROFILE' => $profile,
         'SEARCH_IMG' => $search_img,
         'SEARCH' => $search,
         'PM_IMG' => $pm_img,
         'PM' => $pm,
         'EMAIL_IMG' => $email_img,
         'EMAIL' => $email,
         'WWW_IMG' => $www_img,
         'WWW' => $www,
         'ICQ_STATUS_IMG' => $icq_status_img,
         'ICQ_IMG' => $icq_img,
         'ICQ' => $icq,
         'AIM_IMG' => $aim_img,
         'AIM' => $aim,
         'MSN_IMG' => $msn_img,
         'MSN' => $msn,
         'YIM_IMG' => $yim_img,
         'YIM' => $yim,
         'U_VIEWPROFILE' => append_sid("profile.$phpEx?mode=viewprofile&amp;" . POST_USERS_URL . "=$user_id"))
      $i++;
   while ( $row = $db->sql_fetchrow($result) );
if ( $mode != 'topten' || $board_config['topics_per_page'] < 10 )
   $sql = "SELECT count(*) AS total
      WHERE user_id <> " . ANONYMOUS;
      message_die(GENERAL_ERROR, 'Error getting total users', '', __LINE__, __FILE__, $sql);
   if ( $total = $db->sql_fetchrow($result) )
      $total_members = $total['total'];
      $pagination = generate_pagination("memberlist.$phpEx?mode=$mode&amp;order=$sort_order", $total_members, $board_config['topics_per_page'], $start). '&nbsp;';
   $pagination = '&nbsp;';
   $total_members = 10;
   'PAGINATION' => $pagination,
   'PAGE_NUMBER' => sprintf($lang['Page_of'], ( floor( $start / $board_config['topics_per_page'] ) + 1 ), ceil( $total_members / $board_config['topics_per_page'] )),
   'L_GOTO_PAGE' => $lang['Goto_page'])
$template->pparse('body');
include($phpbb_root_path . 'includes/page_tail.'.$phpEx);
Add To be sure that you have all:
<form method="post" action="{S_MODE_ACTION}">
  <table width="100%" cellspacing="2" cellpadding="2" border="0" align="center">
     <td align="left"><span class="nav"><a href="{U_INDEX}" class="nav">{L_INDEX}</a></span></td>
     <td align="right" nowrap="nowrap"><span class="genmed">{L_SELECT_SORT_METHOD}:&nbsp;{S_MODE_SELECT}&nbsp;&nbsp;{L_ORDER}&nbsp;{S_ORDER_SELECT}&nbsp;&nbsp;
      <input type="submit" name="submit" value="{L_SUBMIT}" class="liteoption" />
      </span></td>
  </table>
  <table width="100%" cellpadding="3" cellspacing="1" border="0" class="forumline">
     <th height="25" class="thCornerL" nowrap="nowrap">#</th>
     <th class="thTop" nowrap="nowrap">&nbsp;</th>
     <th class="thTop" nowrap="nowrap">{L_USERNAME}</th>
<!-- Start add - Rank in member list MOD -->
<th class="thTop" nowrap="nowrap">{L_USER_RANK}</th>
<!-- End add - Rank in member list MOD -->
     <th class="thTop" nowrap="nowrap">{L_EMAIL}</th>
     <th class="thTop" nowrap="nowrap">{L_FROM}</th>
     <th class="thTop" nowrap="nowrap">{L_JOINED}</th>
     <th class="thTop" nowrap="nowrap">{L_POSTS}</th>
     <th class="thCornerR" nowrap="nowrap">{L_WEBSITE}</th>
   <!-- BEGIN memberrow -->
     <td class="{memberrow.ROW_CLASS}" align="center"><span class="gen">&nbsp;{memberrow.ROW_NUMBER}&nbsp;</span></td>
     <td class="{memberrow.ROW_CLASS}" align="center">&nbsp;{memberrow.PM_IMG}&nbsp;</td>
     <td class="{memberrow.ROW_CLASS}" align="center"><span class="gen"><a href="{memberrow.U_VIEWPROFILE}" class="gen">{memberrow.USERNAME}</a><br />{memberrow.ONLINESTATUS}</span></td>
<td class="{memberrow.ROW_CLASS}" align="center" valign="middle"><span class="gensmall">{memberrow.USER_RANK_IMG}{memberrow.USER_RANK}</span></td>
     <td class="{memberrow.ROW_CLASS}" align="center" valign="middle">&nbsp;{memberrow.EMAIL_IMG}&nbsp;</td>
     <td class="{memberrow.ROW_CLASS}" align="center" valign="middle"><span class="gen">{memberrow.FROM}</span></td>
     <td class="{memberrow.ROW_CLASS}" align="center" valign="middle"><span class="gensmall">{memberrow.JOINED}</span></td>
     <td class="{memberrow.ROW_CLASS}" align="center" valign="middle"><span class="gen">{memberrow.POSTS}</span></td>
     <td class="{memberrow.ROW_CLASS}" align="center">&nbsp;{memberrow.WWW_IMG}&nbsp;</td>
   <!-- END memberrow -->
     <td class="catBottom" colspan="9" height="28">&nbsp;</td>
  </table>
  <table width="100%" cellspacing="2" border="0" align="center" cellpadding="2">
     <td align="right" valign="top"></td>
  </table>
<table width="100%" cellspacing="0" cellpadding="0" border="0">
   <td><span class="nav">{PAGE_NUMBER}</span></td>
   <td align="right"><span class="gensmall">{S_TIMEZONE}</span><br /><span class="nav">{PAGINATION}</span></td>
</table></form>
<table width="100%" cellspacing="2" border="0" align="center">
   <td valign="top" align="right">{JUMPBOX}</td>
</table>
Thakn you for your help.
feldon
Beitragvon AmigaLink » 10. Jan 2005 21:07
Oh Sorry, i have forget a little part in the installation guide. :oops:
Take this memberlist.php and it will work! :D
BTW - in the next version (i release it in a few days), the status will be added to the groupcp. 8)
memberlist.php.zip
(4 KiB) 9939-mal heruntergeladen
Beitragvon feldon » 10. Jan 2005 22:48
GREAT :!: :!: :!:
Thank YOU VERY VERY MUCH :!: :!: :!:
That's the best service I ever GET from somebody on internet :!: :!: :!:
btw: Now I see also here under ADD ATTACHEMENT :roll:
Blessed Be
feldon
Beitragvon AmigaLink » 10. Jan 2005 23:03
No Problem :!:
I am finally interest my mods error free run. :wink:
Beitragvon feldon » 10. Jan 2005 23:11
Glad that I could help :lol: :lol: :lol:
feldon
Beitragvon steve » 12. Jan 2005 06:26
very good mod!!
steve
Beitragvon AmigaLink » 12. Jan 2005 06:30
THX :)
Zurück zu Another Online/Offline Indicator
