Problem in Memberlist.php
Online-Statusanzeige im Profil, der Viewtopic und in der Mitgliederliste
Beitragvon J.S. Coolen » 2. Mär 2005 02:12
I have a little problem with memberlist.php:
Parse error: parse error, unexpected T_ELSE in /var/www/html/kennis/memberlist.php on line 318
It was wroking fine before I updated the file
-- Codeblock replace with attachment by Admin -
memberlist.zip
(4.07 KiB) 5177-mal heruntergeladen
J.S. Coolen
Beitragvon AmigaLink » 2. Mär 2005 03:05
Please do not post so lange codeblocks and attach them as zip, rar or ace File!
To your problem: You have placed the code at the wrong place! The attached file shold be work. :)
fixed memberlist.zip
(4.07 KiB) 5208-mal heruntergeladen
Beitragvon J.S. Coolen » 2. Mär 2005 11:40
Thanks, The page is working. But at the memberlist I can't see if somebody is online or offline:
http://www.jcsl.nl/kennis/memberlist.php
J.S. Coolen
Beitragvon AmigaLink » 2. Mär 2005 12:05
Have you changed an upload your memberlist_body.tpl???
Beitragvon J.S. Coolen » 2. Mär 2005 13:09
yes.
But I found the problem.
You replaced this:
// <!-- BEGIN Another Online/Offline indicator -->
      if ( !$row['user_allow_viewonline'] && $userdata['user_level'] == ADMIN || $row['user_allow_viewonline'] )
         $current_time = time();
         $expiry_time = $current_time - 300;
         if ( $row['user_session_time'] >= $expiry_time )
            $user_onlinestatus = '<img src="' . $images['Online'] . '" alt="' . $lang['Online'] . '" title="' . $lang['Online'] . '" border="0" />';
            if ( !$row['user_allow_viewonline'] && $userdata['user_level'] == ADMIN )
               $user_onlinestatus = '<img src="' . $images['Hidden_Admin'] . '" alt="' . $lang['Hidden'] . '" title="' . $lang['Hidden'] . '" border="0" />';
            $user_onlinestatus = '<img src="' . $images['Offline'] . '" alt="' . $lang['Offline'] . '" title="' . $lang['Offline'] . '" border="0" />';
               $user_onlinestatus = '<img src="' . $images['Offline'] . '" alt="' . $lang['Hidden'] . '" title="' . $lang['Hidden'] . '" border="0" />';
// <!-- END Another Online/Offline indicator -->
But I had to placed a 2 lines down.
I placed the file for you to see.
Thanks for your support
memberlist.zip
(4.08 KiB) 5310-mal heruntergeladen
J.S. Coolen
Beitragvon AmigaLink » 2. Mär 2005 17:07
Fine :D
Zurück zu Another Online/Offline Indicator
