if ( $board_config['allow_namechange'] || $mode == 'register' )
if ( empty($username) )
// Error is already triggered, since one field is empty.
$error = TRUE;
else if ( $username != $userdata['username'] || $mode == 'register' )
if (strtolower($username) != strtolower($userdata['username']))
$result = validate_username($username);
if ( $result['error'] )
$error = TRUE;
$error_msg .= ( ( isset($error_msg) ) ? '<br />' : '' ) . $result['error_msg'];
if (!$error)
$username_sql = "username = '" . str_replace("\'", "''", $username) . "', ";
}// <!-- BEGIN easyUCP -->
if ( $ucp_mode )
$s_hidden_fields .= '<input type="hidden" class="post" name="ucp_mode" value="' . $ucp_mode . '" />';
$template->assign_vars(array(
'UCP_CANCEL' => ' <INPUT TYPE="submit" VALUE="'. $lang['Cancel'] . '" name="ucp_cancel" class="liteoption" />',)
if ( $ucp_mode !='require' )
$s_hidden_fields .= '<input type="hidden" class="post" name="email" value="' . $userdata['user_email'] . '" />';
// <!-- END easyUCP -->// <!-- BEGIN easyUCP -->
if ( $ucp_mode )
$s_hidden_fields .= '<input type="hidden" class="post" name="username" value="' . $username . '" />';
// <!-- END easyUCP -->$s_hidden_fields .= '<input type="hidden" class="post" name="username" value="' . $username . '" />';I'm not sure why only some people have this problem and others do not. I wonder if it has something to do with php settings.
if ( $ucp_mode )
if ( $ucp_mode !='ucp_require' )
if ( $board_config['allow_namechange'] )
